  3. Need help in writing Skill for routing between two different...
  • Replies 11
  • Views 19921
Need help in writing Skill for routing between two different MOS
RAGHU2634
RAGHU2634 over 8 years ago
I am starting with skill learning. Please help me with below mentioned query
Two different mos have been spaced apart having their sources common. I want to join these sources using dbcreatepath(). How to extract co-ordinates of these two sources ? So i can use them to connect them using path.
Raghu
    Andrew Beckett over 8 years ago in reply to RAGHU2634 +1
    Raghu, Well, if something gives an error, it's rather helpful to know what the error actually was - otherwise I have no idea what you're doing wrong - that code should work. If the terminal was incorrectly…
    You either need to select the instance and then do: instID=car(geGetSelSet()) (the car is needed because geGetSelSet returns a list of selected items, and the code I gave only needs the first). Alternatively…
  • RAGHU2634
    RAGHU2634 over 8 years ago in reply to Andrew Beckett +1
    Hi Andrew, Thank you . The code was working if P-cell is having only one finger . I am able to get exactly what i wanted. what if my instance is multiple fingered but still i will get only one co-ordinate…
  • RAGHU2634
     I am just into skill learning. Thanks for the info.
    Raghu
