  3. using auto-vias through SKILL
  • Replies 12
  • Subscribers 150
  • Views 25191
Leonardo Vinci
Leonardo Vinci over 8 years ago
I have a list of bBoxes of path shapes of 0.05um width (M1, M2, M3 overlapping/stacked on each other) in my current hierarchy. I have dbIDs of shapes as well. I tried to use function "dbCreateViaShapeArray" but it requires calculations of how many vias we can place(and this could change upon different lengths of the overlapping paths, i could calculate the length of path by subtracting starting y and ending y from their bBoxes, but still it is not generalized for different path lengths).  And also it is not giving equal enclosures of both the ends of the paths.
The requirement here for me is to use auto-via function somehow on these overlapping shapes somehow through SKILL code because auto-via is giving me required proper results.
So, how to use auto-via on these overlapping path shapes to get the desired result.
  • Quek
    Quek over 8 years ago +1
    Hi Leonardo Vinci Starting from IC617, you can use functions such as viaGenerateViasAtPoint to automatically create vias. It is the SKILL equivalent of autovia function. Please see $CDSHOME/doc/sklayoutref…
    Andrew Beckett over 8 years ago in reply to Leonardo Vinci +1
    You could always try support.cadence.com or the "Support" link at the top of this page: BTW, I did some searching around the time Quek responded and only found one report of an issue with slowness…
  • Leonardo Vinci
    Leonardo Vinci over 8 years ago in reply to Andrew Beckett +1
    I have used viaGenerateViasAtPoint(), viaGenerateViasFromShapes() and viaGenerateViasInAr​ea() interchangeably for the same task, but i am still facing issues and to my surprise, the time required by the…
  • Leonardo Vinci
    Leonardo Vinci over 8 years ago in reply to Quek
    Yes, i have. They are looking into the matter, the R&D team.
    UPDATE: I used this function in VXL mode. They said that the issue is related to checkout and check-in of license each time this functions is executed, so when executed in loop for putting vias, it takes time. It takes check-out/in 12 tokens each time and thus takes time. Also, If i run Layout EAD, the same script runs quickly as i needed because there  it checks for license only once for the loop and not each time for the loop. Also they said that the engine for autoVia() GUi and viaGenerateViasAtPoint() is same but there is difference in the number of token usage, autoVia() takes 4 tokens, while viaGenerateViasAtPoint() takes 12 token for performing the same task.  The way this operation(viaGenerateViasAtPoint()) is designed to perform in VXL by Cadence is really very sad for the customers.    Andrew Beckett or anyone else, any comments on this?
    Since you're already interacting with customer support on this, I'll let them comment rather than duplicating work (plus I'd have to research the details of what has been done via the support case that you didn't provide the number for).
