  3. how to direct Virtuoso Visualization and Analysis XL to...
  • Replies 12
  • Views 12558
how to direct Virtuoso Visualization and Analysis XL to display all signals in single window/Strip?
DavidLou
DavidLou over 8 years ago
hello exports,
I had a simple testcase setup in ADE-L with signals to be plotted for a "tran" simulation. when all signals to be plot are analog, they all go to a single waveform window which is fine.
but after I convert a few signals as digital by a2d function in ADE-L and re-run the simulation, the signals are now plotted into multiple subwindows.
from ADE-L output setup, I don't see any control to direct the signals to be plotted all together or in separated waveform windows. Even I save the setup as Ocean Script, I don't see any directing to multiple waveform windows either.
how can this waveform display windows be controlled to plot always in single plot instead I have manually drag them together everytime?
thanks,
David
    Andrew Beckett over 8 years ago in reply to DavidLou
    Hi David,
    Hmm, that is odd, as -restore is pretty similar to just doing a load() after starting. That compares with replay, which is effectively feeding each line in the file to the main event loop.
    I think in principle both should work - so something strange is going on here.
    Please contact customer support so that we can investigate this in more detail.
  • DavidLou
    DavidLou over 8 years ago in reply to Andrew Beckett
    cool, thanks Andrew
