  3. Is it possible to use rodFillBBoxWithRects with elementsX...
  • Replies 12
  • Views 21063
Is it possible to use rodFillBBoxWithRects with elementsX or elementsY similar to rodCreateRect
harisps
harisps over 7 years ago
Hi All,
    I would like to fill BBox with contacts and need to create rows or columns of the same fillBBox. "rodFillBBoxWithRects " will do the filling of contacts in the specified fillBBox but there is no feature like elementsX,elementsY,spaceX,spaceY (spacing between them) etc. similar to rodCreateRect.
1) One way that I have tried to create fillBBox and use it as a mosaic with elementsX,elementsY,spaceX,spaceY.
2) rodCreateRect with ?subRectArray option, But it leads to more calculations for width, length and spacings
Is there any easy way to do the same?
  • harisps
    harisps over 7 years ago in reply to Andrew Beckett
    Sorry for it.
    I have inputs like mosaic (either t or nil, radio button in cdf), rows,cols,spaceX and spaceY, Using this inputs, can I implement mosaic functionality in skill ?
    Andrew Beckett over 7 years ago in reply to harisps
    if(mosaic then
       dbCreateParamSimpleMosaicByMasterName(pcCellView "lib" "cell" "layout" "" 0:0 "R0" rows cols spaceX spaceY list(...))
    else
      ; do whatever  you want when the mosaic is off
    Presumably you could have worked that out yourself though (since you already mentioned that you were using dbCreateParamSimpleMosaic in pcell code). So I am guessing you're trying (and failing) to ask something else?
