  3. CDS_SRR doesn't
  • Views 3991
CDS_SRR doesn't
wgtkan
wgtkan over 6 years ago
Hello:
My MMSIM version is MMSIM151
Spectre version is spectre181
sub-version  18.1.0.235.isr3
The Linux operation system is: Red Hat Enterprise Linux Workstation release 6.7 (Santiago)
My Matlab version is R2018B.  I have read all the previous posting regarding interfacing Matlab with Spectre. I have RF toolbox version 3.5.
I followed  Andrew Beckett’s excellent example on how to interface Matlab with Spectre by reading this post:   https://community.cadence.com/cadence_technology_forums/f/rf-design/21507/working-with-dc-sweeps-and-op
and this post: https://community.cadence.com/cadence_technology_forums/f/rf-design/22435/interfacing-spectre-parametric-analysis-result-to-matlab-in-command
The cds_srr function doesn’t exist in the Matlab and when I read the spectreuser documentation, it mentions about the Multi_mode  Simulation (MMSIM) Toolbox for Matlab but not in detail. I do not seem to find the MMSIM documentation. I get the error that says Undefined function or variable 'cds_srr' in Matlab.
What function should I use?
Thank you very much in advance.
    OK, first of all you don't need both SPECTRE and MMSIM in your path - SPECTRE supersedes MMSIM.
    You need to do this:
    setenv MATLABPATH `cds_root spectre`/tools/spectre/matlab/64bit
    or
    setenv MATLABPATH `spectre_root`/tools/spectre/matlab/64bit
    To ensure the cds_srr utility (the Spectre toolbox) is in your path. BTW, the Matlab "RF" toolbox isn't needed for this.
    Andrew Beckett over 6 years ago in reply to Andrew Beckett
    BTW, for the documentation, it's not in the Spectre User Guide. It's in the Spectre RF Theory. Simplest thing is to run <SPECTREinstDir>/bin/cdnshelp and search for "matlab". You'll then find one of the hits is the "The Spectre/RF MATLAB Toolbox"
  • wgtkan
    wgtkan over 6 years ago in reply to Andrew Beckett
    Hello Andrew,
    Thank you for your prompt response.
    When I added in .bashrc the entry:
    export MATLABPATH=`spectre_root`/tools/spectre/matlab/64bit
    I get bash: spectre_root: command not found.
    I also do source .bashrc
    And also in this post:  https://community.cadence.com/cadence_technology_forums/f/rf-design/21507/working-with-dc-sweeps-and-op
    In Matlab when I do:
    gm=cds_srr('./idcurvesw.raw','sweepvgs_dc-sweep','m1:gm');
    contour(getfield(gm,'vgs:dc'),gm.dc,gm.S);
    I get an error that says vgs:dc is a variable that doesn't exisit. But when I check the output the variable name has changed to vgs_dc and it works when I change the variable:
    contour(getfield(gm,'vgs_dc'),gm.dc,gm.S);
    Thanks a lot.
    Andrew Beckett over 6 years ago in reply to wgtkan
    Perhaps you have wrapper scripts in the way in your environment and maybe when you do "which spectre" it's not actually spectre from a Cadence installation - and because of that "which spectre_root" gives an error. Anyway, the key its that you need to have MATLABPATH set to include the path to the tools/spectre/matlab/64bit dir underneath a SPECTRE installation.
    You're right the field is now called 'vgc_dc'. I suspect that was a fix to avoid having colon in the the name that's been made at some point in the 7 years since I posted that suggestion in the thread you mentioned. One benefit is that you can now avoid having to call getfield (that was essential because of the colon in the field name) and do:
    contour(gm.vgs_dc,gm.dc,gm.S);
