  3. can multiple functionality's assigned to same bindkey
  • Replies 11
  • Subscribers 148
  • Views 7220
RAGHU2634
RAGHU2634 over 7 years ago
Is there any way so we can assign multiple functionalities to the  same bindkey
For eg :
on selecting metal 1  & pressing( ctrl + 1 ) it is converted to metal2 .if (ctrl+1) is pressed i.e; twice  again it should change to metal3 & so on...
Note : I am not doing the above one . I am doing something similar. Please let me  know how to approach this
Raghu
    Andrew Beckett over 7 years ago +1
    Hi Raghu, Isn't that just a matter of having your function look at the layer of the shape that is selected, and if it's on metal1 move to metal2, if on metal2 move to metal3 and so on? It sounds like…
    Andrew Beckett over 7 years ago in reply to RAGHU2634 +1
    For repeated commands like this you'd probably need to use an enterFunction of some sort to prompt you do to something. It's not really very clear what you're trying to do. Andrew.
    Search in the forums for (say) enterPoints - that will give you a number of different examples using one of the enter functions. There are a number of other enterFunctions (all of which begin with "enter…
    Hi Raghu,
    I'm guessing you want something like this:
    procedure(RNgetOverlapShape(overlap)
      if(listp(overlap) then
        RNgetOverlapShape(cadr(overlap))
      else
        overlap
    procedure(RNconnectivity(@optional pt (cv geGetEditCellView()))
      let((overlaps shape layerTable layers
          ; change this list to the metals in your technology
          (metalLayers list("Metal1" "Metal2" "Metal3" "Metal4" "Metal5" "Metal6"))
          stopMetals)
        unless(pt
          pt=hiGetCommandPoint()
        overlaps=dbGetOverlaps(cv list(pt pt) t 20)
        ; collect the layers that appear at the point
        ; does this by flattening the overaps and finding
        ; the layer name of the final shape, then making a
        ; unique list
        layerTable=makeTable('layerTable nil)
        foreach(elem overlaps
          shape=RNgetOverlapShape(elem)
          when(shape~>objType!="inst" && shape~>layerName
            layerTable[shape~>layerName]=t
        layers=layerTable->?
        foreach(layer layers
          remainingMetal=member(layer metalLayers)
          when(cdr(remainingMetal)
            ; not convinced this is really what you want...
            stopMetals=outfile("./stoplayers" "w")
            fprintf(stopMetals "stopLayers(\n %L" list(cadr(remainingMetal) "drawing"))
            when(cddr(remainingMetal)
              fprintf(stopMetals " %L" list(caddr(remainingMetal) "drawing"))
            fprintf(stopMetals " t)\n")
            close(stopMetals)
            leMarkNet(
              pt
              ?stopLevel 20
              ?optionFile "./stoplayers"
              ?thickLine t
              ?markNetColor "y1"
    procedure(RNconnectivityEFaddPoint(wid points)
      RNconnectivity(car(last(points)))
    procedure(RNconnectivityEF()
      enterPoints(
        ?prompts list("Click at point to mark")
        ?addPointProc "RNconnectivityEFaddPoint"
    Note that I don't think using the stop layers like this is quite what you want. This code is trying to set the stop layers two above the metal layer the shape under the cursor. You can also call it from RNconnectivityEF() which uses enterPoints to prompt you to click, and then escape will end the prompting.
    Anyway, hopefully this gives you enough of a framework for you to adapt to your needs.
