  3. Mapping for DPAR_ param name
  • Replies 11
  • Views 5516
rrahul
rrahul over 6 years ago
I am trying to call a netlist procedure and need to create different netlist based on the parameter set from maestro run . But i can only get parmeter names like DPAR_1 , DPAR_2 . How can i get the mapping to orignal parameters in my cell ? Is there a  mapping skill function available , which i can use inside my skill netlist procedure ?
  • rrahul
    rrahul over 6 years ago in reply to rrahul
    I just found that i can use , for example
    nlGetParamStringValue( inst 'spacing)
    to get the corresponding DPAR_ variable for spacing (in this case )
    which can be used together with
    asiGetDesignVarList(asiGetCurrentSession())
    to get mapping and hopefully my issue is solved .
    Thanks anyways
