  3. Use SKILL Code as Parameter Value for Instances in a Sc...
  • Replies 13
  • Subscribers 150
  • Views 17851
Use SKILL Code as Parameter Value for Instances in a Schematic
FormerMember
FormerMember over 6 years ago
I have a several cells which contain a schematic view and an 'sp' view. The 'sp' view is an S-parameter text file, which is referenced by an 'nport' in the schematic via the 'file' parameter.
However, only the absolute path to the 'sp' view file is saved at the moment, which becomes invalid every time the cell is moved or copied. My question is, if it is possible to use a SKILL function, or similar, to point the nport always to the sp view of the schematic, it is placed in.
    Andrew Beckett over 6 years ago in reply to FormerMember
    Attached is an example using ADE Explorer (I didn't know which ADE you were using), which stores the s-parameter files in text views, and then sweeps an integer variable "x" between 1 and 2 (it could be extended). Essentially I've defined the variables as follows:
    Variable Expression
    SPVIEW sprintf(nil "%L" case(round(VAR("x")) (1 "splc1") (2 "splc2")))
    SPCELL "myblock"
    SPLIB "mylib"
    SPFILE sprintf(nil "%L" ddGetObj(VAR("SPLIB") VAR("SPCELL") VAR("SPVIEW") "text.txt")~>readPath)
    x 1,2
    Personally I would have done this instead, as it makes it simpler (this is what I had originally):
    Variable Expression
    SPVIEW "splc1","splc2"
    SPCELL "myblock"
    SPLIB "mylib"
    In other words, just sweep the view string and not bother with the bit that sweeps an integer.
    The nport in the schematic is just a normal analogLib nport, with the filename set to be a variable, and SPFILE as the variable for the file to reference. As you can see, the SPFILE is a SKILL expression which references the source lib/cell/view and retrieves the file. The sprintf() stuff is to ensure there are quotes around the file name.
    Hope that helps?
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/48/sparamViewSweep.tgz
  • FormerMember
    FormerMember over 5 years ago in reply to Andrew Beckett
    I am using the netlistProcedure approach for some time now with spectre and it works quite well. However, now I want to run some AMS simulations with the modified nport as well. I guess I also have to use an own netlistProcedure here, but I cant get it to work. The generated netlist does not contain any modified nport instance.
    Andrew Beckett over 5 years ago in reply to FormerMember
    Hi Paul,
    It ought to work with the same netlist procedure for spectre (because the AMS UNL netlister uses the spectre netlister under the hood). Are you essentially using the netlist procedure above for spectre? If not, can you post it here?
    By the way, in IC6.1.8/ICADVM20.1 ISR16 (out later this month), the analogLib nport will have the ability to specify a lib/cell/view on the instance.
