  3. Create custom ruler to report pre- or post-shrink value
  • Replies 11
  • Subscribers 150
  • Views 9610
Sheppie
Sheppie over 6 years ago
We're working on a product in a technology which gets shrunk down. What we draw in the layout in a layout editor window, will be shrunk down by 0.855. So a drawn dimension of 1um (1000nm) becomes 0.855um (855nm). Currently we're in the floorplanning phase and in discussions about the final die-size. So every time I measure the new die-size (after more and more blocks report a more realistic area), I have to remember to apply this scaling factor before I report any new values.
With the bindkey <k>  the default ruler can be used to measure, and this ruler measures drawn dimensions. I'd like to have somehting like <shift.><k> to give me a ruler which applies the scaling factor to the measurement. Preferably in a different collor to be able to destinguish from one another.
Is this possible? Can I define my own ruler?
Thank you in advance.
With kind regards,
Sjoerd
  • Sheppie
    Sheppie over 6 years ago in reply to Andrew Beckett
    Hi Andrew, This is code from many many years ago, before I learned that a procedure can do type-checking itself. It depends on what type of procedure I write, but if it is for common/general use, I do the type-checking like you proposed, otherwise I just skip it. And yes, it eliminates a lot of lines of code. Kind regards, Sjoerd
