  3. Merge BBOX in hierarchical layout
  • Replies 11
  • Views 24311
mpshetty
mpshetty over 6 years ago
Hi Team,
Problem Statement:In hierarchical layout, I want to get BBOX of particular layer without actually flattening the layout.
Description:The layer can be at any hierarchical depth i.e both from PCELL or shapes but at top level if they are overlapping then I want the merged BBOX.
Now, I am able to get BBOX of all the shapes present at different hierarchy.But i finding issue in merging BBOX.
Please can help me on the same issue as I require efficient way to merge the BBOX because list containing the BBOX is huge.
Thanks in advance.
Regrads,
Prasanna
    Andrew Beckett over 6 years ago in reply to Andrew Beckett +1
    Prasanna, I was feeling generous as it was raining outside. The second function below should do what you want. /* abGetHierLayerBBox.il Author A.D.Beckett Group Custom IC (UK), Cadence Design Systems…
  • mpshetty
    mpshetty over 6 years ago in reply to Andrew Beckett
    Thanks for the information.
    Previously I was not aware of ABE function.Its really helpful :) .
    -Prasanna
