  3. How To Create a Field for Symbol (Symbol Field) in a given...
  • Replies 11
  • Views 21076
How To Create a Field for Symbol (Symbol Field) in a given Form !!!
Sonu Chopra
Sonu Chopra over 6 years ago
Hello everyone ,
I have one query regarding the creation of field for symbol in a form  . I am not able to find the corresponding hiCreateField Command for the symbol Field (float , int , string , list , bBox I was able to but not for symbol)
Can Someone Please guide me how to create a field for symbol in a given form ?  or Could you please tell me the corresponding skill command for symbol field?
Regards
Sonu
    Andrew Beckett over 6 years ago in reply to mbracht +1
    It really sounds as if you're using the resulting string incorrectly - converting to a symbol sounds a really bad approach. Symbols should be used for names of objects - using them to avoid quotation marks…
  • mbracht
    mbracht over 6 years ago in reply to Sonu Chopra +1
    so you are writing into a file aren't you? Use fprintf() with the correct format specification (fprintf <oport> "%s" my_Form~>my_Field~>value) ...an there will be no quotes.
  • Sonu Chopra
    Sonu Chopra over 6 years ago in reply to mbracht
    Hello Max,
    Yes , Now its clear . On my side the mistake was that I was using the %L (which is the Print Representation)
    Regards
    Sonu
