  3. Add pins via skill to all symbols in lib
  • Replies 11
  • Views 22531
HoWei
HoWei over 6 years ago
I received an IP technology package from the foundry.
The package contains of:
- oa-lib with symbols only
- CDL/Spice netlist
Now I included the oa-lib with symbols and want to import the spice netlist into this library.
The problem is, that all the symbols do not have any supply pin - but the netlist has supply pins for each sub-circuits (e.g. VDD, VSS, VNW, VPW).
The import will fail as long this discrepancy exists.
One way to handle this discrepancy is to add the missing pins to the symbols via skill (there might be other options as well , line global nets, etc., but we would like to have additional pins for flexibility).
I would like to add a VDD pin on top and a VSS pin at the bottom of the symbol for each symbol in the library.
My questions:
1. My skill skills are rather nil, so I am asking if someone can send me a skill-code that I can use as a starter and customize to match my requirements ?
2. Can you share your experience with such IP import into Virtuoso (e.g. for standard-cells or GPIO libs) - is it the common way to do a lot of customization to the IP package ? I would expect to get symbols for the standard-cells for which you can just by the symbol tell if its an AND, NAND, INV, OR - but apparently this is not the case.
3. Is there any other option on how to import this netlist into the lib ?
HoWei
  • HoWei
    There remains one more issue while saving a changed symbol view.
    When applying my skill-script (see below) to newly generated cells (e.g. testsymbol_org, testsymbol_org2) the script runs without any error.
    load("myskill_addonly")
    Pins will be added in: 632 testsymbol_org symbol
    debug: after open
    debug: before save
    debug: before reopen for read
    debug: before close
    t
    Pins will be added in: 632 testsymbol_org2 symbol
    debug: after open
    debug: before save
    debug: before close
    t
    But when I apply the script to a copied cell, the following warning occures:
    Pins will be added in: 632 testsymbol_org_copy symbol
    debug: after open
    debug: before save
    *WARNING* (DB-260016): dbOpenBag: Unable to open property bag for 'symbol' in 'r' mode because the associated '/icd/proj/user_worklibs/users/uidn5147/sos/uidn5147_libs/wk_holger_generic/testsymbol_org_copy/symbol/data.dm' file is empty. Make sure the file is checked out correctly or remove the empty file.
    debug: before close
    t
    The script still seems to work properly, but what does this warning mean ?
    My skill-code:
    libName= "wk_holger_generic"
    cellName="testsymbol_org_copy"
    viewName="symbol"
    printf("Pins will be added in: %d %s %s \n" viewCount cellName viewName )
    cvId=dbOpenCellViewByType(libName cellName viewName "schematicSymbol" "a")
    printf("debug: after open \n")
    ;get the boundary Box of the symbol-view
    bBoxCoord=cvId~>bBox
    ;printf("bBoxCoord: %L \n" bBoxCoord)
    ;extract the symbol dimensions xy coordinates of the lower-left and upper-right corner
    llx=nth(0 nth(0 bBoxCoord))
    lly=nth(1 nth(0 bBoxCoord))
    urx=nth(0 nth(1 bBoxCoord))
    ury=nth(1 nth(1 bBoxCoord))
    ;printf("BBox ll_x: %f lly: %f urx: %f ury: %f\n\n" llx lly urx ury)
    ;define new pin height and width
    pinH=0.122
    pinW=0.0625
    ;calculate the pin coordinates and draw pin and label
    pinName="VDD"
    pinx= -0.25
    piny= ury+0.0625
    pinCoord= list( pinx-pinW/2:piny-pinH/2
      pinx-pinW/2:piny+pinH/2
      pinx+pinW/2:piny+pinH/2
      pinx+pinW/2:piny-pinH/2
    schDrawSymbolPin(cvId pinName "inputOutput" pinCoord)
    schCreateSymbolLabel(cvId pinx:piny-0.125 "pin name" pinName "centerCenter" "R0" "stick" 0.0625 "NLPLabel"  )
    printf("debug: before save \n")
    dbSave(cvId) ; save changes
    printf("debug: before reopen for read\n")
    dbReopen(cvId "r")  ;make readonly
    printf("debug: before close \n")
    dbClose(cvId)  ;close file
