  3. How can I check symbol's ports and symbol's name in a schematic...
  • Replies 13
  • Subscribers 152
  • Views 10389
How can I check symbol's ports and symbol's name in a schematic ?
ichiro
ichiro over 4 years ago
Hi all,
I'd like to check and write some symbol's port name and the symbol's name in a schematic to a file by skill.
Do you have sample code?
Best regards,
Ichiro
  • ebecheto
    ebecheto over 4 years ago in reply to ichiro +1
    if you hit "space bar", while having selected the instance, it will end up to connect the cell like that ! No need skill for this feature, already made. (although a skill script is behind that obviously…
  • Kevin Buck
    Kevin Buck over 4 years ago in reply to ichiro +1
    You can use a foreach loop to iterate through the terminals on a symbol and use centerBox to get the appropriate coordinates. foreach(term oldSymView~>terminals ;Generate offset for pin locations and…
  • Kevin Buck
    From the CIW: Options->Bindkeys... will give you a list of shortcuts mapped to keystrokes.
  • ichiro
    ichiro over 4 years ago in reply to ichiro
    I could run "test()" without using SKILLIDE.
    Thanks!!
    Andrew Beckett over 4 years ago in reply to ichiro
    The SKILL IDE has a File->Open and Load menu (or FIle->Load to re-load any file that's opened in a an editor window). There's no need to be typing load("...") in the CIW.
    Note that your code calling schHiTree(cvId) won't work because schHiTree expects a window id, not a cellView id.
  • ichiro
    ichiro over 4 years ago in reply to Andrew Beckett
    Thanks Andrew,
     I don't know why "cvID code" was working well but new code is working well now.
    community.cadence.com/.../how-to-get-the-windowid
    procedure( test()
    wiId =geOpen(
    ?lib "test"
    ?cell "TEST"
    ?view "schematic"
    ?mode "r"
    schHiTree(wiId)
    ); procedure
