  3. How to make a pin from net (or wire)?
  • Replies 15
  • Subscribers 152
  • Views 27457
shyoon
shyoon over 4 years ago
Hello Guys,
I want to automatically make pins from Net name or symbols.
(Cadence version : 6.1.8)
And I do not know the SKill well.
Can I get some help?
Thank you!
  • Kevin Buck
    Kevin Buck over 4 years ago in reply to shyoon
    There was a typo. yourLibName is the object of the target library that you get from ddGetObj. If you haven't assigned a string with the name of the cell you want to yourCellName then it will also give you an error.
    yourLibName=ddGetObj("shyoons_library") ;this is the name of the library that your schematic is in
    Andrew Beckett over 4 years ago in reply to Kevin Buck
    Also, there's no need to pass a dd object to dbOpenCellViewByType - a string with the library name would be sufficient:
    yourLibName="shyoons_library"
    (trying to keep things simple for shyoon)
  • Kevin Buck
    Kevin Buck over 4 years ago in reply to Andrew Beckett
    Good point, that's right. I'm always doing other things with this object so I use it by default but a string also works just fine!
  • shyoon
    shyoon over 4 years ago in reply to Kevin Buck
    Maybe I'm not approaching it well. I made the script you told me into an .il file and loaded it from CIW, but I keep getting an unbound error.
  • Kevin Buck
    The procedure outlined should work fine. Unbound error just means that you are using a variable that has not been assigned so re-check your code.
