  3. awvSaveToCSV
  • Views 12690
awvSaveToCSV
CharlieZhu
CharlieZhu over 4 years ago
Hi All,
I have a question on using awvSaveToCSV function. When I am running corners, the csv file keeps getting overwritten as I write the expression as awvSaveToCSV(data "result.csv").
Is there a way to set the filename of the csv with a variable? Specifically, I learned that I could get the corner name of current sweep using axlGetCornerNameForCurrentPointInRun(). I am hoping that I could combine the two expressions so that I could do something like awvSaveToCSV(data "axlGetCornerNameForCurrentPointInRun().csv").
Thanks in advance for any help and suggestion.
Charlie
    awvSaveToCSV(data strcat(axlGetCornerNameForCurrentPointInRun() ".csv"))
    Note that this is fine if you're just sweeping corners - if you're doing variable sweeps you might need a different strategy, but maybe this is OK. Another approach might be to save into the PSF directory for each simulation point, and so then you could use:
    awvSaveToCSV(data strcat(asiGetPsfDir(asiGetCurrentSession()) "/result.csv"))
  • CharlieZhu
    CharlieZhu over 4 years ago in reply to Andrew Beckett
    Thank you Andrew. strcat is what I am looking for.
