  3. Virtue SKILL and Python Library
  • Replies 15
  • Views 21556
Curtisma
Curtisma over 4 years ago
All:
I put together a SKILL++ library, Virtue, which provides the following features.
Please let me know if you have any feedback on it.
  • A standard library of functions for common tasks
  • A test framework modeled after pytest
  • A TOML config file reader and writer
  • A package import system that allows the library to define just a single top-level import table symbol that allows each package to be imported locally.
It's available at:
https://github.com/cascode-labs/virtue
-Curtis
    Andrew Beckett over 4 years ago in reply to AurelBuche +1
    AurelBuche said: package = (let nil (defun a nil nil) (defun b nil nil) (theEnvironment) ) One downside of this approach is it means that everything in the lexical scope then becomes visible via the…
  • Curtisma
    Curtisma over 4 years ago in reply to AurelBuche +1
    Het Aurel: Thanks for the feedback! Packages Thanks for the good suggestion! This will be particularly helpful for the test framework where I would definitely prefer not to have to add each function…
    Andrew Beckett over 4 years ago in reply to Curtisma +1
    I've not seen that, and I just experimented with using the code above, even putting it inside a function so that the effects of lazy compilation might show up, and putting additional code beyond the macro…
    I've not seen that, and I just experimented with using the code above, even putting it inside a function so that the effects of lazy compilation might show up, and putting additional code beyond the macro call, with breakpoints on those lines and all worked fine.
    Macros should be used sparingly because you're effectively creating a new language when you use them and that can be jarring for a reader of the code, but this seems a pretty good application for macros. You could write a function instead and use run-time evaluation - which in this case since it's only going to be at load time wouldn't be too awful - but it's much less elegant (and I see no good reason given that the macro works fine with the IDE). I'm not aware of issues with the IDE with macros - maybe they have been resolved?
    (defun PkgExportFunc (env @rest functions)
      (let ((pkgTable (makeTable 'pkgTable nil)))
        (foreach func functions
    	     (setarray pkgTable func (symeval func env)))
        pkgTable))
    and then use:
    (PkgExportFunc (theEnvironment) 'set 'get)
    to do the export.
    Andrew Beckett over 4 years ago in reply to Andrew Beckett
    Curtis,
    On reflection (and I’ve. It tried this), the one place I can imagine the IDE might struggle with is putting  break points on code within the arguments of a macro because it doesn’t know which line that ends up on. Possibly… I’d have to check. Obviously that’s not going to be something you’d want to do with the macro I suggested as the arguments are symbols and not code.
    So i don’t see this as a reason to avoid all macros.
  • Curtisma
    Curtisma over 4 years ago in reply to Andrew Beckett
    Awesome! That looks great, thanks Andrew Beckett!
  • AurelBuche
    AurelBuche over 4 years ago in reply to Curtisma
    I do but I cannot use my personal account at work and even if I enjoy coding in SKILL I don't usually do it on my personal computer which has no access to Virtuoso Sweat smile
  • Curtisma
    All:
    I released a new version, v0.4, of Virtue recently.
    Documentation:https://www.cascode-labs.org/virtue
    Release Notes: https://www.cascode-labs.org/virtue/overview/release_notes.html
    -Curtis
    Andrew Beckett, AurelBuche
