  3. How to plot Transient Value for every DC value in DC sweep...
  • Views 10302
How to plot Transient Value for every DC value in DC sweep in Cadence.
Tong011201
Tong011201 over 3 years ago
I am using Cadence 6.1.8 - 64b. I need to plot a result from the transient analysis (Settling Time: settlingTime(IT("/V0/PLUS") ymax(IT("/V0/PLUS")) nil value(IT("/V0/PLUS") 0.8m   ) nil 1 nil "time" ) ) for every DC voltage value in the DC sweep. Also, the x-axis needs to be another DC sweep output (Power:  (( IS("/N12/D") + IS("/P11/S") + IS("/P10/S") + IS("/N10/D") + IS("/N15/D")) * 3 +( IS("/P6/S") + IS("/N11/D") ) * 2.7 ) *4 ). I wonder how I can do that.
    ShawnLogan over 3 years ago
    Dear Tong011201,
    One way might be:
    1. Define each (settling time and power) as outputs in Explorer or Assembler.
    2. Run the set of transient simulations as your vary the DC voltage.
    3. Plot each output in two Viva windows (settling time versus DC voltage in one plot and power versus DC voltage in a second plot)
    4. Export each waveform from Viva to distinct comma-separated variable files, say settling_time.csv and power.csv
    5. Create a new comma-separated variable file whose first column is the second column power.csv and whose second column is the second column of settling_time.csv. This can be done with a UNIX awk command, as an example:
    awk 'BEGIN{FS=",";} {print $2}' settling_time.csv > second_column_setting_time.csv
    awk 'BEGIN{FS=",";} {print $2}' power.csv > second_column_power.csv
    paste -d","  second_column_power.csv second_column_setting_time.csv > settling_time_vs_power.csv
    6. Use the function getAsciiWave() to create a waveform from your csv file "settling_time_vs_power.csv"  and plot the waveform; alternately use the SKILL function CCSCreateWaveCSV() at URL:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000009ETw3UAG&pageName=ArticleContent
    Shawn
    ShawnLogan over 3 years ago in reply to ShawnLogan
    Dear Tong111201,
    A second way, which is easier, is to utilize the relatively new Calculator waveVsWave() function. Its function prototype and an example are at the URL:
    support.cadence.com/.../techpubDocViewerPage
    and
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000005xH8aEAE&pageName=ArticleContent
    respectively. In your case, the expression might read:
    waveVsWave(?x power,settling_time ?y "Power" ?xName "Power")
    Shawn
  • Tong011201
    Tong011201 over 3 years ago in reply to ShawnLogan
    I cannot access these two links since I am a student using a school's cadence license. Is there any way that I can view these without logging in?
    Andrew Beckett over 3 years ago in reply to Tong011201
    waveVsWave is documented in the help information shipped with Virtuoso (which is essentially what you'd be getting from the first link above; the second is just an example).
    In Virtuoso, in any window, use the Help menu and in the type-in box at the top of the menu type "waveVsWave" and it should take you to relevant help.
  • Tong011201
    Tong011201 over 3 years ago in reply to Andrew Beckett
    Got it. Thank you.
