  3. connect two metal nets
  • Replies 15
  • Subscribers 153
  • Views 23361
Deeksha D
Deeksha D over 3 years ago
I am trying to connect two metal nets (objType~>path).
if both metal net layers are same then simply align nets abutted.
if nets have different metal layers then check if metals layers can be connected using VIA .
eg if metals layers are M1 and M2 then connect using VIA1 taking via's  min.  width and min. enclosure by metal from techfile,
    Andrew Beckett over 3 years ago in reply to Deeksha D +1
    Deeksha D said: Yes, I have partially selected metal bus (path/path seg) in horizontal and vertical path. I want to connect these metals using skill and if the metal types are different Vias need to be…
    Andrew Beckett over 3 years ago in reply to RicardoGV1 +1
    I'm using the viaGenerateViasAtPoint() SKILL function to place the vias. It turns out that if you are not using VLS EAD (in IC6.1.8) or VLS EXL (in ICADVM20.1), then it checks out GXL tokens instead. Potentially…
    Andrew Beckett over 3 years ago in reply to Vallabha
    Vallabha,
    I've updated the code above (I edited the original post to replace with a newer version) which should handle the constraint group either being in a reference technology library, or even in the design. Apologies for this - a silly oversight on my part.
    Hopefully you can try that and it should (I hope) work for you.
  • Vallabha
    Vallabha over 3 years ago in reply to Andrew Beckett
    Thanks Andrew for the updated code.
    The updated code is giving me the following error.
    Vallabha
    Vallabha,
    Please ensure that the code is in a file with a ".ils" suffix (not ".il") before loading it. This ensures it will be read using SKILL++ semantics (that's what the SCHEME message is about). That should fix the problem.
  • Vallabha
    Andrew,
    The code is working perfectly.
    Thank you very much!
    Vallabha
  • sksheerasagar
    sksheerasagar over 3 years ago
    i  just used your code
    can we have a code where we can join metals in reverse order and also a code without any via addition if they are of different metals just the buses should interact in both normal and reverse order.
    With Regards,
    Sagar
