  3. Calculating Area (AbArea) but getting results show on pop...
  • Views 6511
Calculating Area (AbArea) but getting results show on pop-up instead in CIW
JJAP
JJAP over 2 years ago
I found this skill code helpful but can you help modifying this? The area result shows in the CIW, can the result be shown through pop up window instead?
* (abArea object) *
* Calculate the area of an object. *
* Currently only works with polygons and rectangles. *
(procedure (abArea object)
(let (sum crd lastPt firstPt crdList area corners ll ur dx dy objType)
(setq objType (dbGetq object objType))
(if (equal objType "polygon")
(progn
(setq crdList (dbGetq object points))
(setq sum 0)
(setq firstPt (setq lastPt (car crdList)))
(setq crdList (cdr crdList))
(foreach crd crdList
(setq dx (difference (xCoord crd) (xCoord lastPt)))
(setq sum (plus sum (times dx (plus (yCoord crd) (yCoord lastPt)))))
(setq lastPt crd))
(setq sum (plus sum
(times (difference (xCoord firstPt) (xCoord lastPt))
(plus (yCoord firstPt) (yCoord lastPt)))))
(setq area (times 0.5 (abs sum))))
(when (equal objType "rect")
(setq corners (dbGetq object bBox))
(setq ll (car corners))
(setq ur (cadr corners))
(setq dx (difference (xCoord ll) (xCoord ur)))
(setq dy (difference (yCoord ll) (yCoord ur)))
(setq area (abs (times dx dy))))
area))
procedure(abAreaOfObject(@optional (object car(geGetSelSet())))
println(abArea(object))
  • mbracht
    mbracht over 2 years ago
    Replace
    against
       (hiDisplayUserDBox ?name 'someDialog
          ?dboxText (sprintf nil "Area: %5.2f" (abArea object) )
          ?buttons (list "Ok")
    Max
  • JJAP
    JJAP over 2 years ago in reply to mbracht
    Thanks Max! Really appreciate it.
