  3. Where on the keyboard can I find ' and " ?
  • Subscribers 148
  • Views 1190
Marben
Marben over 2 years ago
Hi All,
Because I have the code below, I want to make a pop up menu.
Item_Handle1 = hiCreateMenuItem(
?name      'menu_item_name
?itemText  "Any text you want "
?callback  "procedure_name()"
Please help.
Best regards,
Marben
    How did you type the code then? This seems a very odd question - and will depend heavily on what keyboard you have and if it’s set up properly on your computer and in Linux (it’s not really anything to do with Virtuoso).
  • Marben
    Marben over 2 years ago in reply to Andrew Beckett
    I copied and paste it,
    I can not find in keyboard the ' and " , if I want to type
    it manually.
    Does the character ' and " , exist in keyboard?
    This is a SKILL code to make a pop up menu in layout.
    Item_Handle2 = hiCreateMenuItem(
    ?name          'menu_item_name2
    ?itemText      "Any text you want2 "
    ?callback      "procedure_name2"
    ; Add Items Handle below to be displayed in menu
    hiCreateMenu(
             'Menu_Name
                    "Menu Header"
             list(
                                  Item_Handle1
                                  Item_Handle2
    ;Specify bindkey
    hiSetBindKey("Layout"    "<Key>1"    "hiDisplayMenu(Menu_Name)" )
    Best regards,
    Marben
    Andrew Beckett over 2 years ago in reply to Marben
    I suggest you speak to somebody in your IT team. A keyboard without quotation marks sounds pretty strange to me. As I said, precisely where the quotation marks are located will depend on the country/keyboard but it’s normally pretty obvious in my experience. How you do anything without quotation marks beats me!
