  3. How to access the value of a boolean button within a form...
  • Replies 20
  • Views 16163
How to access the value of a boolean button within a form within a docked window
blankman
blankman over 2 years ago
I have a form, within a docked window, within my session window. And within that form I have a boolean button. How do I access the value of that boolean button?
I have tried this, however is not accessing it:
hiGetCurrentForm()~>bool1~>value
B
  • blankman
    blankman over 2 years ago in reply to Andrew Beckett
    Andrew, Ok, see updated below adding button to DockForm, this new button functions differently depending on the state of bool1. Thanks, B
    [EDIT: code removed]
    Andrew Beckett over 2 years ago in reply to blankman
    I changed the button callback to be the name of the function (it could have been a local function or a lambda, but I didn't want to confuse you with understanding lexical scoping and SKILL++), and in that case it receives information about the field and the scope (the form in this case). Because of this, it will get the form for the specific window you're in - and thus will work. I'm not sure why you need to set a global variable "Test" in your callback (that said your code is lacking let() functions across the board and is not being careful to declare local variables). This part of the code is what I changed (other than indenting to make the code a bit clearer):
    ; used by app_create_dwin(swin)
    procedure(DockFormProc()
      button1=hiCreateButton(
        ?name 'button1
        ?buttonText "Ticked/Unticked?"
        ; pass the name of the function so that it gets called
        ; as a "function object callback" (search in docs for that
        ; string)
        ?callback 'UseBoolTest
      bool1 = hiCreateBooleanButton(
        ?name 'bool1
        ?buttonText " "
        ?buttonLocation 'right
      DockForm=hiCreateAppForm(
        ?name gensym('DockFormApp)
        ?formTitle "Test"
        ?fields
        list( list(button1 0:3 165:18)
          list(bool1 86:25 15:2 25)
      DockForm
    ;target proc that I intend to use the value of the boolean button in.
    ; for buttons, these only have two arguments (no value)
    procedure(UseBoolTest(field form)
      Test = nil
      if(form->bool1->value == nil
        then Test = "a"
          printf("Button is unticked\n")
        else Test = "b"
          printf("Button is ticked\n")
  • blankman
    Thanks Andrew, works perfectly, yes I had removed much of the finer details (let statements etc) for the test case. Appreciate the support, very helpful, thanks, B
  • blankman
    blankman over 2 years ago in reply to blankman
    Hi Andrew, another quick question, say I want to add this proc UseBoolTest to a bindkey, what should I pass for variables field and form in the below code? See error I am seeing following. K Rgds, B
    hiSetBindKey("Layout" "1" "UseBoolTest()")
    *Error* BRSADI11Oct2023EnableMetals123: too few arguments (2 expected, 0 given) - nil
    If you add this function to your code (or something like it):
    procedure(CCFfindAssistant(assistantName @optional
        (swin hiGetSessionWindow(hiGetCurrentWindow())))
      car(
        exists(
          assistant
          setof(dwin hiGetWindowList('dockable)
            hiGetSessionWindow(dwin)==swin && hiGetWindowState(dwin)=='mapped)
          hiGetWindowName(assistant)==assistantName
    Then you can set your bindkey to be:
    hiSetBindKey("Layout" "1" "UseBoolTest('button1 symeval(CCFfindAssistant(\"Test\")->hiForm))")
    The idea is that CCFfindAssistant looks for an assistant which is associated with the current session window and is mapped (so it's visible) which has the window name matching the given argument (this is the "title" of your docked window). Having found that, it then gets the symbol associated with the form in that docked window and evaluates it to get the form handle - and then passes the two arguments to your UseBoolTest function. The first argument is just the name of the field but since your callback is  not using the field name it probably doesn't matter.
  • blankman
    Thanks Andrew, this works, and yes the first argument is not showing to matter on my side, as I have just set this up across multiple different bindkeys that use multiple different buttons, and it still works. Thank again, B
  • blankman
    Andrew, I am seeing some unexpected behaviour using the bindkey allocation. After a period of time of successful use I get the following error and the bindkey stops working.
    *Error* symeval: argument #1 should be a symbol (type template = "se") - nil
    Though I notice when I again call the UseBoolTest proc directly (by clicking button1 within DockForm) the bindkey again begins to function correctly. I cannot see what might be causing this. Any ideas what might be happening here?
    K Rgds, B
    The only reason I can think of is that CCFfindAssistant is not finding the assistant (for some reason) and is returning nil. I don't know why that would happen - I might try doing:
    trace(CCFfindAssistant hiGetWindowState hiGetWindowName hiGetSessionWindow)
    to see if that gives any clues when it's failing. Might be a bit noisy in normal use - but it might give some clues as to what is going on.
  • blankman
    Thanks Andrew, here is what I see from CIW when I try and use the bindkey, when the bindkey is not functional with aforementioned error. Is this what you are looking for? Rgds, B
    |[1]CCFfindAssistant("Test")
    |[2]hiGetSessionWindow(window:12)
    |[2]hiGetSessionWindow --> swindow:11
    |[2]hiGetSessionWindow(dwindow:1)
    |[2]hiGetSessionWindow(dwindow:2)
    |[2]hiGetSessionWindow(dwindow:3)
    |[2]hiGetSessionWindow(dwindow:4)
    |[2]hiGetSessionWindow(dwindow:5)
    |[2]hiGetSessionWindow(dwindow:6)
    |[2]hiGetSessionWindow(dwindow:7)
    |[2]hiGetSessionWindow(dwindow:8)
    |[2]hiGetSessionWindow(dwindow:9)
    |[2]hiGetSessionWindow(dwindow:10)
    |[2]hiGetSessionWindow(dwindow:11)
    |[2]hiGetSessionWindow(dwindow:85)
    |[2]hiGetSessionWindow --> swindow:9
    |[2]hiGetSessionWindow(dwindow:86)
    |[2]hiGetSessionWindow(dwindow:87)
    |[2]hiGetSessionWindow(dwindow:88)
    |[2]hiGetSessionWindow(dwindow:89)
    |[2]hiGetSessionWindow(dwindow:90)
    |[2]hiGetSessionWindow(dwindow:91)
    |[2]hiGetSessionWindow(dwindow:92)
    |[2]hiGetSessionWindow(dwindow:93)
    |[2]hiGetSessionWindow(dwindow:94)
    |[2]hiGetSessionWindow(dwindow:95)
    |[2]hiGetSessionWindow(dwindow:96)
    |[2]hiGetSessionWindow(dwindow:97)
    |[2]hiGetSessionWindow(dwindow:98)
    |[2]hiGetSessionWindow --> swindow:10
    |[2]hiGetSessionWindow(dwindow:99)
    |[2]hiGetSessionWindow(dwindow:100)
    |[2]hiGetSessionWindow(dwindow:101)
    |[2]hiGetSessionWindow(dwindow:102)
    |[2]hiGetSessionWindow(dwindow:103)
    |[2]hiGetSessionWindow(dwindow:104)
    |[2]hiGetWindowState(dwindow:104)
    |[2]hiGetWindowState --> unmapped
    |[2]hiGetSessionWindow(dwindow:105)
    |[2]hiGetWindowState(dwindow:105)
    |[2]hiGetSessionWindow(dwindow:106)
    |[2]hiGetWindowState(dwindow:106)
    |[2]hiGetSessionWindow(dwindow:107)
    |[2]hiGetWindowState(dwindow:107)
    |[2]hiGetSessionWindow(dwindow:108)
    |[2]hiGetWindowState(dwindow:108)
    |[2]hiGetSessionWindow(dwindow:109)
    |[2]hiGetWindowState(dwindow:109)
    |[2]hiGetWindowState --> mapped
    |[2]hiGetSessionWindow(dwindow:110)
    |[2]hiGetWindowState(dwindow:110)
    |[2]hiGetSessionWindow(dwindow:111)
    |[2]hiGetWindowState(dwindow:111)
    |[2]hiGetSessionWindow(dwindow:112)
    |[2]hiGetWindowState(dwindow:112)
    |[2]hiGetSessionWindow(dwindow:113)
    |[2]hiGetWindowState(dwindow:113)
    |[2]hiGetSessionWindow(dwindow:114)
    |[2]hiGetWindowState(dwindow:114)
    |[2]hiGetSessionWindow(dwindow:126)
    |[2]hiGetSessionWindow --> swindow:13
    |[2]hiGetSessionWindow(dwindow:127)
    |[2]hiGetSessionWindow(dwindow:128)
    |[2]hiGetSessionWindow(dwindow:129)
    |[2]hiGetSessionWindow(dwindow:130)
    |[2]hiGetSessionWindow(dwindow:131)
    |[2]hiGetWindowName(dwindow:109)
    |[2]hiGetWindowName --> "Property Editor"
    |[2]hiGetWindowName(dwindow:110)
    |[2]hiGetWindowName --> "Palette"
    |[2]hiGetWindowName(dwindow:112)
    |[2]hiGetWindowName --> "Navigator"
    |[1]CCFfindAssistant --> nil
    |[2]hiGetWindowState(...)
    |[2]hiGetWindowState --> ...
    |[4]hiGetWindowState(...)
    |[4]hiGetWindowState --> ...
    |[3]hiGetSessionWindow(...)
    |[3]hiGetSessionWindow --> ...
    |[4]hiGetSessionWindow(...)
    |[4]hiGetSessionWindow --> ...
    |[5]hiGetSessionWindow(...)
    |[5]hiGetSessionWindow --> ...
  • blankman
    Thanks Andrew, I am getting a long output from CIW. I had tried posting it here but it marked as spam. Is there any way I can get this to you?
