  3. get/getq: first arg must be either symbol, list, defstruct...
  • Subscribers 148
  • Views 2486
get/getq: first arg must be either symbol, list, defstruct or user type - 67.45
ramdev
ramdev over 1 year ago
I’m trying to connect a same nets with different metal layers to connect together with a via, when I trying to execute a code it runs. But when I trying to use that it shows this error in ciw window.
here is the code
; Function to check if the object is a metal layer
procedure(dblsMetal(obj)
let((layerName)
layerName = obj~ > layerName
; Adjust the metal layer names as per your environment
member(layer Name '(METAL1" "METAL2" "METAL3" "METAL4" "METAL5" "METAL"))
; Function to determine the appropriate via type based on layer names
procedure(getViaType(layer1 layer2)
let(via Type)
cond(
(equal layer1 "METAL1") && (equal layer2 "METAL2")) (via Type = "VIA12")
(equal layer1 "METAL2" && (equal layer2 "METAL1")) (viaType = "VIA12")
(equal layer1 "METAL2") && (equal layer2 "METAL3")) (viaType = "VIA23")
(equal layer 1 "METAL3") && (equal layer2 "METAL2")) (via Type = "VIA23")
(equal layer 1 "METAL3") && (equal layer2 "METAL4") (via Type = "VIA34")
(equal layer1 "METAL4") && (equal layer2 "METAL3")) (viaType = "VIA34")
((equal layer 1 "METAL4") && (equal layer2 "METALS")) (viaType = "VIA45")
(equal layer 1 "METAL5") && (equal layer2 "METAL")) (viaType = "VIA56")
(equal layer 1 "METAL") && (equal layer2 "METALS")) (via Type = "VIA56")
(t error"Unsupported layer combination for via creation."))
viaType
; Main function to connect metals procedure(connectMetals
let((selection metals sameNetLayer sameNetLayer2 via Type startPoint endPoint)
; Get the selected objects using geGetSelSet for partial selection
selection = geGetSelSetO
unless(selection
error ("No objects selected.")
; Filter selected metals
metals = setof(obj selection dbIsMetal(obj))
; Debug message to print the metals found
printf("Metals selected: %L\n" metals)
; Check if two metals are selected
unless(length(metals) = = 2
error("Please select exactly two metal shapes.")
; Check if metals are on the same net
sameNetLayer = car(metals)
sameNetLayer2 = cadr(metals)
unless(sameNetLayer ~>net == sameNetLayer2~>net
error("Selected metals are not on the same net.")
; Get the starting and ending points for creating the path
startPoint = list((sameNetLayer1~>bBox~>IIx + sameNetLayer~>bBox~>urx) / 2
(sameNetLayer1~>bBox~>Ily + sameNetLayer1~>bBox~>ury) / 2)
endPoint = list((sameNetLayer2~>bBox~>lIx + sameNetLayer2~>bBox~>urx) / 2
(sameNetLayer2~>bBox~>Ily + sameNetLayer2~>bBox~>ury) / 2)
; Check if metals are on the same or different layers
if(sameNetLayer1~>layerName = = sameNetLayer2~> layerName then
; Connect metals directly
printi( Connecting metals directly without via. In')
dCreatePath(sameNetLayer1 ~ > cellView sameNetLayer1 ~ > layerName
sameNetLayer1 ~ > purpose startPoint endPoint
; Determine the via type
via Type = getVia Type(sameNetLayer1~> layerName sameNetLayer2~> layerName)
; Debug message to print the via type
printf("Connecting metals with via type: %5\n" via Type)
; Create a via to connect different layers
dbCreateVia(sameNetLayer1~> cellView viaType startPoint)
; Ensure the Layout window is active and the function is loaded when(hiGetCurrentWindow0 ~>type == "layout"
hiSetBindKey("Layout" "CtrI < Key>c" "connectMetals")
printf("Bindkey for 'connectMetals' is set to Ctri+ c\n*))
    Given that this code is full of errors - spaces in the wrong place, missing parentheses, misspelt function names, debugging it is going to be pretty much impossible. Did you copy and paste it from an image of the code (using some kind of optical character recognition?), because there are so many problems with it that I'd hate to try to guess where the problem is.
  • ramdev
    ramdev over 1 year ago in reply to Andrew Beckett
    Yes andrew i used image to copy it.
    I couldn’t copy. I will try to update same code.
  • ramdev
    procedure(dblsMetal (obj)
    let((layerName)
    layerName = obj~>layerName
    member(layerName '("METAL1" "METAL2" "METAL3" "METAL4" "METAL5" "METAL6"))
    let((viaType)
    cond (
    ((equal layer1 "METAL1") && (equal layer2 "METAL2")) (viaType = "VIA12")
    ((equal layer1 "METAL2") && (equal layer2 "METAL1")) (viaType = "VIA12")
    ((equal layer1 "METAL2") && (equal layer2 "METAL3")) (viaType = "VIA23")
    ((equal layer1 "METAL3") && (equal layer2 "METAL2")) (viaType = "VIA23")
    ((equal layer1 "METAL3") && (equal layer2 "METAL4")) (viaType = "VIA34")
    ((equal layer1 "METAL4") && (equal layer2 "METAL3")) (viaType = "VIA34")
    ((equal layer1 "METAL4") && (equal layer2 "METAL5")) (viaType = "VIA45")
    ((equal layer1 "METAL5") && (equal layer2 "METAL4")) (viaType = "VIA45")
    ((equal layer1 "METAL5") && (equal layer2 "METAL6")) (viaType = "VIA56")
    ((equal layer1 "METAL6") && (equal layer2 "METAL5")) (viaType = "VIA56")
    (t (error "Unsupported layer combination for via creation."))
    viaType
    procedure(connectMetals()
    let((selection metals sameNetLayer1 sameNetLayer2 viaType startPoint endPoint)
    selection = geGetSelSet()
    unless (selection
    error("No objects selected.")
    metals = setof(obj selection dblsMetal(obj))
    unless (length(metals) == 2
    sameNetLayer1 = car(metals)
    unless (sameNetLayer1~>net == sameNetLayer2~>net
    startPoint = list((sameNetLayer1~>bBox~>llx + sameNetLayer1~>bBox~>urx) / 2
    (sameNetLayer1~>bBox~>lly + sameNetLayer1~>bBox~>ury) / 2)
    endPoint = list((sameNetLayer2~>bBox~>llx + sameNetLayer2~>bBox~>urx) / 2
    (sameNetLayer2~>bBox~>lly + sameNetLayer2~>bBox~>ury) / 2)
    if (sameNetLayer1~>layerName == sameNetLayer2~>layerName) then
    printf("Connecting metals directly without via.\n")
    dbCreatePath(sameNetLayer1~>cellView
    sameNetLayer1~>purpose
    else
    viaType = getViaType(sameNetLayer1~>layerName sameNetLayer2~>layerName)
    printf("Connecting metals with via type: %s\n" viaType)
    dbCreateVia(sameNetLayer1~>cellView viaType startPoint)
    when (hiGetCurrentWindow()~>type == "layout"
    hiSetBindKey("Layout" "Ctrl<Key>c" "connectMetals()")
    printf("Bindkey for 'connectMetals' is set to Ctrl+c\n")
    Andrew Beckett over 1 year ago in reply to ramdev
    There's still lots of spaces in the wrong place, parentheses wrong and so on. However, it fails because of this:
    You can't use ~>llx and ~>urx etc on a bounding box (which is a list of lists). Instead, I'd suggest:
    destructuringBind(((llx lly) (urx ury)) sameNetLayer1~>bBox
      startPoint=list((llx+urx)/2 (lly+ury)/2)
    destructuringBind(((llx lly) (urx ury)) sameNetLayer2~>bBox
      endPoint=list((llx+urx)/2 (lly+ury)/2)
    After that, the via creation code is just wrong. You need to find the via def from the tech file, and you weren't giving the right number of arguments for the dbCreateVia function. Also the dbCreatePath is incorrect - see the comments below.
    In future, please make sure that the code you post actually runs (at least runs with the same errors you are seeing). Figuring out which errors were due to optical character recognition failures and which were the bugs in your code is not a good use of time for volunteers on this forum.
    Anyway, here's the corrected* code. * - the metal layers and vias were changed, and I'm not sure the code actually does what you want, but it does seem to run in my limited testing (well, I didn't test the branch where it got to dbCreatePath, because that will certainly fail as is).
    procedure(dbIsMetal(obj)
      let((layerName)
        member(layerName '("Metal1" "Metal2" "Metal3" "Metal4" "Metal5" "Metal6"))
      let((viaType)
        cond(
          (((equal layer1 "Metal1") && (equal layer2 "Metal2")) viaType = "M2_M1")
          (((equal layer1 "Metal2") && (equal layer2 "Metal1")) viaType = "M2_M1")
          (((equal layer1 "Metal2") && (equal layer2 "Metal3")) viaType = "M3_M2")
          (((equal layer1 "Metal3") && (equal layer2 "Metal2")) viaType = "M3_M2")
          (((equal layer1 "Metal3") && (equal layer2 "Metal4")) viaType = "M4_M3")
          (((equal layer1 "Metal4") && (equal layer2 "Metal3")) viaType = "M4_M3")
          (((equal layer1 "Metal4") && (equal layer2 "Metal5")) viaType = "M5_M4")
          (((equal layer1 "Metal5") && (equal layer2 "Metal4")) viaType = "M5_M4")
          (((equal layer1 "Metal5") && (equal layer2 "Metal6")) viaType = "M6_M5")
          (((equal layer1 "Metal6") && (equal layer2 "Metal5")) viaType = "M6_M5")
        viaType
         tfId viaDef)
        unless(selection
        unless(length(metals) == 2
        unless(sameNetLayer1~>net == sameNetLayer2~>net
        if(sameNetLayer1~>layerName == sameNetLayer2~>layerName then
          ;;; THIS IS INCORRECT. The second argument should be a list of layer
          ;;; and purpose. The third should be a list of start and end points.
          ;;; A fourth argument (the path width) is required too.
            startPoint endPoint
        else
          tfId=techGetTechFile(sameNetLayer1~>cellView)
          viaDef=techFindViaDefByName(tfId viaType)
          dbCreateVia(sameNetLayer1~>cellView viaDef startPoint "R0")
    ; this just doesn't work!
    when(hiGetCurrentWindow()~>type == "layout"
    hiSetBindKey("Layout" "Ctrl<Key>" "connectMetals()")
  • ramdev
    Thanks andrew
    I will check on this.
