  3. Calibration on ADC - Calculations are all correct - but...
  • Views 797
Calibration on ADC - Calculations are all correct - but plotting doesn't work on sweeps?!
jehh
jehh 7 months ago
I am trying to do a calibration of an ADC using the calculator functions. I keep getting issues with unbound variables from my calibration calculations.
Steps that I am using (roughly sketched, do a bunch of similar calculations):
1) create digital word bus using:
awvCreateBus("code_out" list(awvAnalog2Digital(VT("/code_x<9>") nil nil 0.5 nil "centre") awvAnalog2Digital(VT("/code_x<8>") nil nil 0.5 nil "centre") awvAnalog2Digital(VT("/code_x<7>") nil nil 0.5 nil "centre") awvAnalog2Digital(VT("/code_x<6>") nil nil 0.5 nil "centre") awvAnalog2Digital(VT("/code_x<5>") nil nil 0.5 nil "centre") awvAnalog2Digital(VT("/code_x<4>") nil nil 0.5 nil "centre") awvAnalog2Digital(VT("/code_x<3>") nil nil 0.5 nil "centre") awvAnalog2Digital(VT("/code_x<2>") nil nil 0.5 nil "centre") awvAnalog2Digital(VT("/code_x<1>") nil nil 0.5 nil "centre") awvAnalog2Digital(VT("/code_x<0>") nil nil 0.5 nil "centre")) "Unsigned Decimal")
2)
Then I use a cross statement to get a time value - I use || operator to get 0 if crossing statement fails.
3)
I had some issue with extracting the word at the time but ended up with:
atoi(awvGetScalarFromWave(value(code_out t_v1_calib_sample)))
4)
Then I do some calculations and then I multiply a gain and offset to a wave where I converted the digital code to a an analog waveform using:
code_out_V = clip(awvDigital2Analog(code_out 4.7 0 0 ?mode "busvalue") t_conv_done VAR("simtime"))
code_out_V_corr = ((code_out_V_sample * g_calib) + o_calib)
Now the issue:
When running a single point simulation this works very well - however when running sweeps I can no longer plot my code_out_V_corr ? It fails saying that a bunch of variables are unbound.
Errors:
ERROR (ADE-1057): Could not evaluate expression
        Expression:'atoi(awvGetScalarFromWave(value(code_out t_v2_calib_sample)))'
     because of the following error(s)
        ("atoi" 0 t nil ("*Error* atoi: argument #1 should be a string (type template = \"tg\")" srrWave:0x67461a60))
     Ensure that the definition of the expression is correct.
*Error* ("atoi" 0 t nil ("*Error* atoi: argument #1 should be a string (type template = \"tg\")" srrWave:0x67461ac0))
        Expression:'atoi(awvGetScalarFromWave(value(code_out t_v1_calib_sample)))'
*Error* ("difference" 0 t nil ("*Error* difference: can't handle (unbound - unbound)"))
        Expression:'(q_fs * ((v2_meas - v1_meas) / (q2_meas - q1_meas)))'
*Error* ("times" 0 t nil ("*Error* times: can't handle (unbound * unbound)"))
        Expression:'(q_fs * (v1_meas - ((q1_meas * g_calib) / q_fs)) * VAR("v_lsb"))'
*Error* ("times" 0 t nil ("*Error* times: can't handle (srrWave:0x67461490 * unbound)"))
        Expression:'((code_out_V_sample * g_calib) + o_calib)'
Version info:
xrun(64)    24.03-s003
Spectre Version 23.1.0.722.isr15 64bit (Running Spectre X simulation
Virtuoso IC23.1-64b.ISR12.37
  • jehh
    jehh 7 months ago
    Some more info: It seems that the atoi caused an issue - I've tried converting the digital bus with awvDigital2Analog -> Which removes the need to convert the list of strings that atoi couldn't handle when you have done a sweep.
