  3. CDF: Modifying the cyclic type cdf choices for a specific...
  • Views 2157
CDF: Modifying the cyclic type cdf choices for a specific instance of the PCell changes the choices for all the instances
Naveen002
Naveen002 7 months ago
Hi Team,
I am creating a PCell, which has a cyclic type cdf. There's a requirement based on some other cdf parameter, I need to modify the cyclic cdf choice dynamically. I have written a call-back for that. But the problem is, when I change the choice in one instance, it gets updated in rest of the instances of the PCell.
I read a similar discussion in the forum (sorry for creating a duplicate), but the post discussed only on the work around rather than why it actually happens.
Usually, when the choices can be changed dynamically, the change must be applied only to a particular instance (for which the cdf is changed) and not to other instances of the same PCell.
If we take the case of changing the cdf values, it's being changed only to the particular instance (not all). Likewise, it should happen with cyclic cdf choices, but it didn't. Could any one please let me know why it's not happening?
Naveen
    Andrew Beckett 7 months ago
    Naveen,
    When you update the CDF, you're actually updating the effective cell CDF. This is shared amongst all instances using that cell - and as you perform edit properties or create instance it updates the effective cell CDF with the current instance's values. If you are updating the choices only in the callback, then that will be retained too.
    The general way to solve this is to also update the choices in the formInitProc for the CDF. That way as each instance is edited, the choices are updated for the settings on that instance (you'd need to also do it in the callbacks so that the choices change as you edit the values on the form). Doing this in the formInitProc means that the choices are updated per instance in the same way that the values are updated in the cell CDF per instance too (that's done by the system).
  • Naveen002
    Naveen002 6 months ago in reply to Andrew Beckett
    Andrew,
    Thanks a lot for your time in responding.
    Got the point from what you said. It worked with a call back function in formInitProc.
    - Naveen
