  3. How to retrieve the number of waves from a srrWave object...
  • Subscribers 150
  • Views 2052
How to retrieve the number of waves from a srrWave object?
unSkilled
unSkilled 6 months ago
I have a filtered leafValue expression:
exprFilt = leafValue(expr "fs" 168.0M)
famIsFamily(exprFilt)
t
I want to retrieve the number of waveforms that are present in that family and plot them in separate subwindows
length(exprFilt) fails as below:
length(exprFilt)
*Error* length: argument must be a list or an array - srrWave:0x0f059720
Using the cross product of sweep parameters is not correct in this case because exprFilt is pre-filtered, Each of the variables has multiple values
famGetSweepName(exprFilt 0)
"modelFiles"
famGetSweepName(exprFilt 1)
"trim_vreg_reg2"
famGetSweepName(exprFilt 2)
"fin"
famGetSweepName(exprFilt 3)
"temperature"
famGetSweepName(exprFilt 4)
"freq"
famGetSweepName(exprFilt 5)
nil
we're not interested in all sweeps but those present in the family only. Is there a way to easily get the number of waves in a family?
  • henker
    henker 6 months ago
    Not sure if there is a nicer way, but a naive approach would be to recursively dive into the family (of families, of ...) until you reach the waves, and sum up the numbers on return, as this would count the actual waves, independent on how the sweeps look like, e.g. like this:
    procedure( count_waves_in_fam(wave)
      let( (cnt)
        cond(
          ( drIsWaveform(wave)
            ; a single wave
            1
          ( famIsFamily(wave)
            ; call self with all family members
            ; sum up the returned count
            cnt = 0
            foreach(sv famGetSweepValues(wave)
              cnt = cnt + count_waves_in_fam( famValue(wave sv) )
            cnt
          ( t
            error("count_waves_in_fam: cannot handle %L\n" wave)
        ); cond
      ); let
    IF the number of waves is actutually not what you finally want, but to open subwindows for each wave, then you might add the opening part inside the 'drIsWaveform(wave)' condition, and replace the foreach with 'famMap('count_waves_in_fam wave)', which should be at least more efficient. However, if you want to pass values up (like the count here) or down (e.g. the current sweep values), then you have to iterate yourself.
  • unSkilled
    unSkilled 6 months ago in reply to henker
    Thanks for your reply. I haven't had the chance to tinker with this in the past days but I'll give it a go and report the outcome in the forum.
