  3. Create many variables with While
  • State Suggested Answer
  • Answers 1
  • Subscribers 20
  • Views 1509
Philippe LC
Philippe LC 3 months ago
Hi
I want to create x variables with the function While
Exemple:
i=1
delta=408
while(nequal(i 8)
axlSingleSelectPoint(sym_x+560:sym_y+delta)
objet = axlGetSelSet()
printf("%s%L" ,"variable" i) ; i create world variable1 first and i want to assign -> variable1 = objet how to declare variable1 ?
delta = delta-4
i=i+1
);end while
  • Philippe LC
    0 Philippe LC 3 months ago
    precision : i want -> variable1 = car(objet)->text
    0 Andrew Beckett 3 months ago in reply to Philippe LC
    First of all, you posted in the Custom IC SKILL whereas you're using Allegro functions, so I moved it to a more appropriate forum.
    Now, I'm a Custom IC guy, so I don't know the Allegro axl APIs, but in general creating variables dynamically like this is not the best approach - you'd be better off using an array. Also, the while loop could be a for loop. If you used an array, it would be:
    declare(varArray[8]) ; the array starts from 0 to 7
    delta=408
    for(i 1 7
      varArray[i]=car(objet)->text
      delta=delta-4
    If you really must create separate 7 different variables (a pseudo array), you could do this:
    delta=408
    for(i 1 7
      set(concat('variable i) car(objet)->text)
      delta=delta-4
    It's a better idea to create an array for array-like data though.
    • Vote Up +2 Vote Down
  • Philippe LC
    Hi Andrew
    Thanks for the answer.
    I test the second solution in a first time. it's perfect .
    I will try with an array later
    Philippe
