  3. How to print all the hierarchies of a cell being used in...
  • Replies 14
  • Views 15202
How to print all the hierarchies of a cell being used in a design using Skill Script?
Ganesh B
Ganesh B 9 months ago
Hi, I want to search a cell used in a top schematic and print the hierarchies of the cell being used, Could you please help? I want to print the hiearchy in terms of cell names not instance names, Thanks in advance.
    Andrew Beckett 9 months ago in reply to Aurel B +1
    Or use Edit->Hierarchy->Print Tree rather than having to write SKILL code. Or if you want to do this from SKILL, you can use schPrintTree or schPrintTreeConfig as a SKILL equivalent (these were added in…
  • Aurel B
    Aurel B 9 months ago in reply to Andrew Beckett +1
    The ones I had in mind were : schProduceUniqueCVHier & schProduceCVHierConfig but I haven't tried them yet. From https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/64551/how-to…
    Andrew Beckett 9 months ago in reply to Ganesh B
    Hi Ganesh,
    Ganesh B said:
    can we print only the "search cell" hierachy instead of printing all the hoerachy in our design? This will reduce our execution time as well as load.
    I don't understand what you mean by the "search cell" hierarchy. Can you please clarify?
  • Ganesh B
    Ganesh B 9 months ago in reply to Andrew Beckett
    What I mean to say is, instead of printing every hierarchy in the design, I want to print only the hierarchy where a particular cell is being used.
    This will be helpful when we r working on a lower cell and want to know where and all hierarchies the cell is being used.
    This wouldn't be any faster as it would still need to visit the entire hierarchy to see whether it is used anywhere.
    So you could just post-process the results to filter out those which have the given cell name in the result hierarchy path.
  • Ganesh B
    Got it Andrew, Thanks.
