  2. Functional Verification Shared Code
  3. vr_ad and AXI eVC integration
  • Subscribers 40
  • Views 26525
archive over 20 years ago
Attached is a file implementing the integration between vr_ad (the register and memory management shareware) and Cadence's AXI eVC. This is a working draft that can be adapted to your own environment. It was developed by Olivier Schuler from STMicroelectronics (many thanks!) and brought to us by Cadence's Patrick Oury.
Avi
Originally posted in cdnusers.org by abehar
vr_ad_axi_config.zip
    Hello Abehar,
    I need to use the vr_ad with the ahb evc instead of the axi evc. Is the technique similar. or does it change
    Originally posted in cdnusers.org by salehn
    There is an example of the hookup between vr_ad and the AHB eVC in the eVC installation. Look in the examples directory.
    Originally posted in cdnusers.org by nick_heaton
    Hello nick,
    I am really grateful for your response. I have tried out the example in the directory u specified.
    i am getting this error when i do the "test" command in specman.
      Opening file for message: vr_ahb.elog
       *** Error: The size of item vr_ad_map-@372 is 0. Add a constraint to specify the correct size
    what could be the reason for this.
    regards,
    nisreen
  • Kamal
    Kamal over 17 years ago
    I am trying to integrate the vr_ad (Cadence utility) into my environment. I have a situation that there are multiple instances of AXI which will try to access a single vr_ad. Please provide me with an example... like the above.
    Thanks, Skamal
  • cmarqu42
    cmarqu42 over 9 years ago
    The code piece
                    for i from 0 to size {
                        result.add(0x0);
    seems to be wrong/superfluous.
    At least in my case, it made the read_reg macro return twice the expected data (with zeroes in the extra bytes), and only those zeroes were then taken (and the actual data stripped off).
