  2. Hardware/Software Co-Development, Verification…
  3. Error during hdlImport
  • Subscribers 48
  • Views 13347
archive over 19 years ago
Note:  following is dialogue between a customer and Cadence engineers on an issue with an error during hdlImport.
Subject: Error during hdlImport
Hi All,
On one of the designs, hdlImport is failed without giving any error message.
I am using hdlImport -2001 command to import the design files.
When I tried to use vavlog then it exit abnormally with "Exit 1" message in the end.
I have used IXE4.0, IXE3.1 version.
Please let me know how should I proceed as there is no error message coming out of the tool.
Cadence answers:
If it is true that you have no error and no prior warning you need to isolate down to the exact module (or better the exact construct) and simply log it with R&D - they have tools which can trace what is going on.
We had something similar with Linux,
Because there were too many hdlInputFile statements ( several 1000 ). We had to split it up and do more hdlImport commands in between. Is that your thing?
Customer response:
The filelist is huge. I will try this workaround.
We are running on Solaris environment.
Cadence comment:
In the past, I have worked around this issue by using a single hdlInputFile -f caf command,
where caf is the file that contains all the -y, -v etc. switches.
Originally posted in cdnusers.org by ashvarma
