  3. License Error on Allegro
  • Subscribers 162
  • Views 30823
prakash
prakash over 17 years ago
I am having a license issue on my server which has on online board extraction tool. When I run Allegro,  I get the following error:
Allegro_Expert, version 15.700 and quantity 1. The license server search path is defined as 5280@xxx.xxx.xxx.com;5280@xxx.xxx.xxx.com;5280@xxx.xxx.xxx.com;7102@xxx.xxx.xxx.com;. The FLEXnet error message is as follows,
FLEXnet ERROR(-18, 0, 0): License server system does not support this feature.
Run 'lic_error LMF-02018' for more information.'
Command >
--> When I check for the license using "C:\Cadence\psd_14.2\bin>lmutil lmstat -f Allegro_Expert -c 5280@XXXXX.XXX.XXXX.com ", I get the following error:
lmutil - Copyright (C) 1989-1999 Globetrotter Software, Inc.
Flexible License Manager status on Mon 12/22/2008 20:37
Error getting feature, No such feature exists (-5,357)
--> When checked for all licenses.the following is the output received:
C:\Cadence\psd_14.2\bin>lmutil lmstat -a
Flexible License Manager status on Tue 12/23/2008 08:54
License server status: 5280@xxx.xxx.xxx.com,5280@xxx.xxx.xxx.com,5
280@xxx.xxx.xxx.com
    License file(s) on xxx.xxx.xxx.com: /var/license/cadence_cdslmd_pglli
c04-tri/cdslmd.dat:
xxx.xxx.xxx.com: license server UP v10.8
xxx.xxx.xxx.com: license server UP (MASTER) v10.8
Vendor daemon status (on xxx.xxx.xxx.com):
    cdslmd: UP v10.8
Feature usage info:
Users of Allegro_PCB_Partitioning:  (Total of 10 licenses available)
Users of Allegro_Viewer_Plus:  (Total of 32 licenses available)
Users of Allegro_design_expert:  (Total of 48 licenses available)
  "Allegro_design_expert" v16.2, vendor: cdslmd
  floating license
    schua1 schua1-mobl 0:0 (v15.700) (xxx.xxx.xxx.com/5280 7722), start T
ue 12/23 6:57
    dlschatz NXPLHIBM127 0:0 (v16.000) (xxx.xxx.xxx.com/5280 7821), start
 Tue 12/23 7:38
Users of Allegro_studio:  (Total of 17 licenses available)
  "Allegro_studio" v16.2, vendor: cdslmd
  floating license
    vmailisx ladhwjer-desk 0:0 (v15.200) (xxx.xxx.xxx.com/5280 3026), sta
rt Tue 12/23 7:38
Users of Base_Verilog_Lib:  (Total of 41 licenses available)
Users of CaptureCIS:  (Total of 1 licenses available)
Users of Capture_CIS_Studio:  (Total of 8 licenses available)
Users of Concept_HDL_expert:  (Total of 24 licenses available)
Users of Extended_Verilog_Lib:  (Total of 41 licenses available)
Users of Optimizer:  (Total of 1 licenses available)
Users of PCB_design_expert:  (Total of 48 licenses available)
  "PCB_design_expert" v16.2, vendor: cdslmd
  floating license
    schua1 schua1-mobl 0:0 (v15.700) (xxx.xxx.xxx.com/5280 4553), start T
ue 12/23 6:57
    dlschatz NXPLHIBM127 0:0 (v16.000) (xxx.xxx.xxx.com/5280 8513), start
 Tue 12/23 7:38
Users of PCB_design_studio:  (Total of 10 licenses available)
Users of PCB_librarian_expert:  (Total of 7 licenses available)
  "PCB_librarian_expert" v16.2, vendor: cdslmd
  floating license
    vmailisx ladhwjer-desk 0:0 (v15.200) (xxx.xxx.xxx.com/5280 152), star
t Tue 12/23 7:37
Users of PSpice:  (Total of 2 licenses available)
Users of PSpiceAD:  (Total of 1 licenses available)
Users of PSpiceStudio:  (Total of 8 licenses available)
Users of PlaceBase_ALL:  (Total of 58 licenses available)
Users of RouteMVIA_ALL:  (Total of 58 licenses available)
Users of SPECCTRA_PCB:  (Total of 10 licenses available)
Users of SPECCTRA_expert:  (Total of 58 licenses available)
Users of adv_package_designer_expert:  (Total of 10 licenses available)
Users of advanced_package_designer:  (Total of 10 licenses available)
Users of expgen:  (Total of 89 licenses available)
Users of pcomp:  (Total of 89 licenses available)
Users of plotVersa:  (Total of 196 licenses available)
License server status: 7102@xxx.xxx.xxx.com    License file(s) on xxx.xxx.xxx.com: C:\license\cam350\cam350.lic:
xxx.xxx.xxx.com: license server UP (MASTER) v10.1
   act_inc: UP v10.1
Feature usage info:
Users of CAM350-110:  (Error: 2 licenses, unsupported by licensed server)
Can you please suggest me, what went wrong and the solution to correct it.
 Thanks in Advance.
  • oldmouldy
    oldmouldy over 17 years ago
    It looks like you have a valid license for Allegro_design_expert for version 16.2 but it would appear that your 15.7 version tool is looking for an Allegro_Expert feature which you don't have, hence the "-18" error. You would need to contact Cadence Support to resolve this, my 15.7 installation checks out an "Allegro_design_expert" feature and correctly uses the 16.2 version feature.
