  3. Bottom-Top design using Concept HDL..
  • Replies 8
  • Views 18995
MAAC
MAAC over 16 years ago
I would like to know the Bottom-Top design approach in HLD...or hierarchical design from Bottom to top..???
Which is prefered one Top-Bottom or Bottom-Top??...I could able to do the Top-Bottom design using Concepthdl_tut.pdf from Doc....
How can we do the Bottom-Top design r is there any user guide for the same.(not the Tools-Genview)
Thnx
  • Jerry GenPart
    Jerry GenPart over 14 years ago
    Make sure that whenever you change the lower level hierarchical block’s signal names that are attached to PORT symbols, that you also insure you either run Genview (to update the corresponding block symbol) or manually modify/add/delete the same signal’s pin name in the block’s symbol view.
    Save both the block schematic and the corresponding symbol view.
    Jerry
  • Samuel Zhang
    Samuel Zhang over 14 years ago
    Hi Jerry. Thank you for your reminding. I already solved this problem. The matter is that I must make 'Generate view' at first before I saving the subdesign which I modify. If I save the subdesign immediately after modifying, the errors will appear.
  • admin
    admin over 12 years ago
    What is this error and how it can be resolved.
    Severity : Error (HDL Direct)
    Description : ERROR(SPCOHD-152): Port on instance does not exist in entity declaration for instance.
    Object dump:
        page:  1
        instance:  I115
        cell name: STM32F103VGT6
        pin name:  PB11/I2C2_SDA/USART3_RX
        page:  1
        instance:  I115
