  3. LogoMaker - improved, and now multi-platform.
  • Replies 75
  • Subscribers 178
  • Views 47693
eDave
eDave over 16 years ago
Please, please, please follow the instructions fully when installing. They are at the top of the Skill file and also here:
Download and install the precompiled potrace release suitable for your platform:
  http://potrace.sourceforge.net/download
 set the POTRACE_PATH environment variable to the path to the executable
  eg. C:\utils\potrace
 Download and install the precompiled ImageMagick release suitable for your platform
 This may not be necessary if you use Linux as ImageMagick is often included in Linux installations:
  http://www.imagemagick.org/script/binary-releases.php
  eg. http://www.imagemagick.org/download/binaries/ImageMagick-6.5.3-Q16-windows.zip
 If the path to the ImageMagick convert.exe file is not in your system path then set the MAGICK_HOME
 environment variable to the path to the convert executable. (Run "convert -version" in a system shell to test).
  eg. C:\utils\ImageMagick\ImageMagick-6.5.1-3
 Install logoMaker_public.il into your skill folder.
 Add load("logoMaker_public.il") to the allegro.ilinit file in your pcbenv folder.
Happy logoing,
Dave
logoMaker_public.il
  • rsbonini
    rsbonini over 11 years ago
    V3.7 appears to work well.  Very nice tool.  Thanks for the excellent support!
  • Dhamodharann
    Dhamodharann over 11 years ago
    Hi all,
                          I am using PC Intel core 2 duo processor with 2 GB RAM with Win 7 Operating system (32 Bit) . What ever the files you listed above to download is not get possible. when i am try to download it make the " Page Not found". Otherwise i had downloaded it from the external link too. The potrace was not get installing, while installing cmd is get executed for certain long time.
    For my operating system which  version of the version could been supported.
    Can you provide the detailed step by step procedure to install  the logo maker. Me was facing lot problems try to download & installing it too.
  • eANIL
    eANIL over 11 years ago
    Hi Dave, I installed previous logo maker, image magic and protrace set up was done its working, If I just download this new .il file and over wright the existing il, is it okay or do I have to do the whole procedure again?
  • eDave
    eDave over 11 years ago
    You can just overwrite.
  • andersmp
    andersmp over 8 years ago
    Hi Dave,
    Are you aware of any issues with running allegro.exe as user and not being able to use the logomaker?
    I get these errors in Command Window:
    E- File save problem: Not enough storage is available to process this command.
    E- *Error* axlFormColorize: argument #1 should be any user-defined (other) type (type template = "otgg") - nil
    Logomaker does load fine when running the program as Administrator.
    Software:
    Windows 10x64
    OrCAD/Allegro 17.2-S009
    ImageMagick-7.0.4-Q16
    potrace-1.13.win64
    logomaker 3.7
    I have tried with earlier versions of ImageMagick as well.
    Kind regards,
    Anders Pedersen
