  3. LogoMaker - improved, and now multi-platform.
  • Replies 75
  • Subscribers 178
  • Views 47653
eDave
eDave over 16 years ago
Please, please, please follow the instructions fully when installing. They are at the top of the Skill file and also here:
Download and install the precompiled potrace release suitable for your platform:
  http://potrace.sourceforge.net/download
 set the POTRACE_PATH environment variable to the path to the executable
  eg. C:\utils\potrace
 Download and install the precompiled ImageMagick release suitable for your platform
 This may not be necessary if you use Linux as ImageMagick is often included in Linux installations:
  http://www.imagemagick.org/script/binary-releases.php
  eg. http://www.imagemagick.org/download/binaries/ImageMagick-6.5.3-Q16-windows.zip
 If the path to the ImageMagick convert.exe file is not in your system path then set the MAGICK_HOME
 environment variable to the path to the convert executable. (Run "convert -version" in a system shell to test).
  eg. C:\utils\ImageMagick\ImageMagick-6.5.1-3
 Install logoMaker_public.il into your skill folder.
 Add load("logoMaker_public.il") to the allegro.ilinit file in your pcbenv folder.
Happy logoing,
Dave
logoMaker_public.il
  • ahmetozsoy
    ahmetozsoy over 16 years ago
    Hi
    It also happened to me. I restart windows XP and then it runs perfectly. I want to thank to Dave for this Logomaker.
    Regards
    Ahmet
  • C Shiva
    C Shiva over 16 years ago
     Ahmet, I tried as you informed. Still same problem. Any help?
  • ahmetozsoy
    Hi Shiva,
    I briefly track Dave's orders that's all. I didn't change the skill file. Only set the paths so that Windows understand where they are.
    In environment variables I set the variables as Dave describes. Maybe Dave helps better.
    Ahmet
  • eDave
    Ahmet's correct - please don't alter the code. Instead ensure that the plugins are correctly installed and your environment variables are set correctly. You don't need to re-boot your system after altering the environment variables (in Windows) but you will need to restart Allegro.
  • C Shiva
     Thanks Dave. It works fine. But when i trying to load mono image with enabling Pre-process option it shows:
     potrace failure
    The potrace utility failed to convert this image to svg.
     With disabling Pre-process option the logo will load. And when i trying to load color images the above error appears. Please help.
    Shiva.
