  3. LogoMaker - improved, and now multi-platform.
  • Replies 75
  • Subscribers 178
  • Views 47683
eDave
eDave over 16 years ago
Please, please, please follow the instructions fully when installing. They are at the top of the Skill file and also here:
Download and install the precompiled potrace release suitable for your platform:
  http://potrace.sourceforge.net/download
 set the POTRACE_PATH environment variable to the path to the executable
  eg. C:\utils\potrace
 Download and install the precompiled ImageMagick release suitable for your platform
 This may not be necessary if you use Linux as ImageMagick is often included in Linux installations:
  http://www.imagemagick.org/script/binary-releases.php
  eg. http://www.imagemagick.org/download/binaries/ImageMagick-6.5.3-Q16-windows.zip
 If the path to the ImageMagick convert.exe file is not in your system path then set the MAGICK_HOME
 environment variable to the path to the convert executable. (Run "convert -version" in a system shell to test).
  eg. C:\utils\ImageMagick\ImageMagick-6.5.1-3
 Install logoMaker_public.il into your skill folder.
 Add load("logoMaker_public.il") to the allegro.ilinit file in your pcbenv folder.
Happy logoing,
Dave
logoMaker_public.il
  • muthussne
    muthussne over 14 years ago
     Hi Dave,
       I have installed Imagemagick in C:\Program Files\ImageMagick-6.7.0-Q16 and potrace download form http://potrace.sourceforge.net/download/potrace-1.8.win32-i386.zip. potrace.exe and mkbitmap.exe files are placed in C:\utils\potrace. In the environment variable i have set the path to potrace in variable value as C:\utils\potrace and imagemagic as C:\Program Files\ImageMagick-6.7.0-Q16.when i run the skill below plugin message is appear... is there any problem in install plugin... if any pls send me the plugin file you used before.
    Plugins
    The LogoMaker Skill utility makes use of three free utilities that need to be
    installed before use:
    1/ potrace - Download the executable from:
        http://potrace.sourceforge.net/download/potrace-1.8.win32-i386.zip (Windows)
    2/ mkbitmap - Distributed with the potrace utility
    3/ ImageMagick
        - Download and install the precompiled release suitable for your platform from:
        This may not be necessary as ImageMagick is pre-installed on many systems
        set the MAGICK_HOME environment variable to the path to the convert executable
    For further information please email: dave.elder@tait.co.nz
  • eDave
    eDave over 14 years ago
    It should be working if you followed the instructions. I have tested it in Windows 7.
    I can't see your images to be able to identify the problem.
    You probably want to download potrace-1.9.win32.zip and ImageMagick-6.7.0-Q16-windows.zip
    ;  Installation instructions:
    ;                Download and install the latest precompiled potrace release suitable for your platform:
    ;                                http://potrace.sourceforge.net/download
    ;                set the POTRACE_PATH environment variable to the path to the executable
    ;                                eg. C:\utils\potrace
    ;                Download and install the latest precompiled ImageMagick release suitable for your platform
    ;                This may not be necessary if you use Linux as ImageMagick is often included in Linux installations:
    ;                                http://www.imagemagick.org/script/binary-releases.php"
    ;                                eg. http://www.imagemagick.org/download/binaries/ImageMagick-6.5.3-Q16-windows.zip
    ;                Set the MAGICK_HOME environment variable to the path to the convert executable.
    ;                                eg. C:\utils\ImageMagick\ImageMagick-6.5.1-3
    ;                Install logoMaker_public.il into your skill folder.
    ;                Add load("logoMaker_public.il") to the allegro.ilinit file in your pcbenv folder.
    ;  Running within Allegro:
    ;                Type logomaker in the command window.
  • spazvt
    spazvt over 14 years ago
    I just successfully installed and used logomaker on two Windows XP machines and wanted to post what worked and didn't work.
     1) %MAGICK_HOME% pointing to "C:/Program Files/ImageMagick-6.7.0-8" wouldn't work, I'm assuming because of the space in the path.  When typing "logomaker" in Allegro, I would get the instructions page instead of the logomaker utility opening.  Placing potrace and imagemagick at "C:/utils/..." did work, though, after I reopened ProjMgr and Allegro.
    2) Loading .jpg files into logomaker, I would recommend unchecking "Preprocess".  I was inserting solid black FCC and Telec logos and using "preprocess" seemed to do an edge detect, whereas I wanted solid logos.
    3) For some reason, once I place the symbols and exit the application, I can't move the symbols.  I do a move command, with Find=Symbol, but when I click the final destination, the symbol snaps back to its original location.
     Jeremy
  • eDave
    The logo symbols are fixed by default. You can unfix them to move. You can also un-tick the "Fix Symbol" check box when placing the symbol. Dave
  • spazvt
     How do you "unfix" the symbol?
     Inside the logomaker tool, it looks like I was using the tool without the "fix" button clicked.  When I place the symbol with the "fix" button checked, I can't select the symbol at all, or even 'info' it.
     I'm using Allegro 16.2.
