  3. Allegro's Capture hijacked my keyboard and mouse?
  • Views 1208
saxe
saxe over 16 years ago
I just installed Allegro's Capture (ver 16.1) on my pc and ran into some problem
Often, when Allegro's Capture is started, I can't click on any menu item to bring down the pull-down menu to do anything. When I minimize Allegro's Capture, I can't even use mouse click nor keyboard to start any application from my desktop. When I close Allegro's Capture, everything is back to normal. It is like Allegro's Capture hijacked my keyboard and mouse. Any suggestion? I've tried two installations of Allegro's Capture already
 Thanks for your help!
 My PC is onlyt two days old, Dell Vostro 220, 3G ram, 2.9G Core 2 Duo CPU, XP-based, with Avast protection
Allegro's Capture works fine in my colleges' pc, the license server is on a linux pc
  • Ejlersen
    Ejlersen over 16 years ago
    Hi
    I would suggest that you uninstall
    Restart the PC and login as administrator, reinstall and try running Capture before logging of as administrator. This should hopefully setup everything correctly in the registration database which is where I expect that the problem is.
    Also try logging into downloads.cadence.com and download the latest ISR for your 16.1 (actually SPB16.01) software.
    Best regards
    Ole
  • saxe
    Uninstalled then reinstalled twice, same problem
    When I tried to enter downloads.cadence.com, it bounced back as "
    ACCESS RESTRICTED"
    If I start capture as the VERY FIRST application, it seems to work fine. I think it may have some problem with the dual cores
  • Ejlersen
    Hi
    I would suggest that you contact Cadence support or your local Cadence Channel Partner to get some help on this issue.
    Best regards
    Ole
