  3. how to create VQFN package???
  • Views 16318
kabalee
kabalee over 15 years ago
 hi
i haven't any idea about thermal pad with vias in package cc 2530.i attached the footprint details.
1.when i create pad in shape symbol i colud not change pad in oneside is rectangel and other side is oblong shape.
2.how to create the thermal pad with vias.(while i creating thermal pad i placed vias over the thermal pad  DRC error occur )
3.what is the defalut tolerance for soldermask top
  • Raam
    Raam over 15 years ago
    1. To create bullet shape pin, First create Shape as pin (file\new\select ''shape symbol'') and save it in ur library, then while creating pad stack, on regular pad option select shape and give the library path of the shape where u saved.
    2. add shape as top etch for thermal pad, then use add connection to draw trace on the thermal shape and double click to drop via one by one, then delet the trace (clines)
    3. 0.254mm + actual pad size = Nominal Solder mask size and maintain solder mask to solder mask minimum 0.1mm air gap.
    Yellaa Pugallum Erivannuke,
    Raam >>--)-->
  • kabalee
    i used allegro15.7..when i draw the custom shape pad(bullet) .i choose shape-->filled pad -->
    and then draw the pad but how to change it bullet shape
    if i choose shape--> composed shape means it is possible to change oblong shape
  • kabalee
    thanks for your reply. i have another dough that is in this package 41 pin is ground that is thermal pad but i create as shape with via. when i import net list means error ll occur. what ll i do ??
  • mcatramb91
    mcatramb91 over 15 years ago
    I know you already got a previous response to your post but I would like to provide you some addition feedback.
    1. You could simple create a shape symbol to represent the bullet shaped pin.  Draw two shapes on Etch/Top, one rectangular and one round, the join them together using Merge Shapes command (Shape > Merge Shapes..)  This shape is then referenced in the padstack.
    2. I would recommend adding 9 thermal pins to your symbol representing the 9 individual paste apertures. This padstack will contain a top pad and top solder paste defined as 1.2mm SQ per solder paste size on the spec sheet. These pins will need to be defined on the schematic symbol and most likely be connected to GND. Create a square shape on Etch/Top and Package Geometry/Soldermask_top in the symbol and add thermal vias per the spec sheet.  Don't be concerned with shape to pin DRCs at the symbol level because once you place the component in a design the shape will automatically adapt/assign to the net name tied to the thermal pads.  One final note: Check with your PCB fabricator to ensure that the thermal vias are small enough to prevent the solderpaste from reflowing down the thermal via holes during assembly.
    3. Speak to your PCB fabricator about the tolerance on the solder mask and also confirm that they will not have any issues with a solder mask web of .08mm between the pins of this device.  The web should not be an issue but it never hurts to confirm and ask for their feedback.
    Hope this helps,
    Mike Catrambone
    Plexus Technology Group
  • girish
    girish over 15 years ago
    You can follow the suggestions given by Mr.Mike
    Here I have shown the pictorial representation for creating your pad.Same thing can be repeat to Soldermask also .
    Girish
