  3. VCC net ratlist
  • Views 19451
VCC net ratlist
Adeshere
Adeshere over 15 years ago
My VCC net does not show the rat line, just a square box with a cross going through it.
How do i get allegro to show me that rat as well as all the others
 thanks
Adrian
  • Rik Lee
    Rik Lee over 15 years ago
    Nets that have a VOLTAGE property or RATSNEST_SCHEDULE = POWER_AND_GROUND property on them will display a box with an X. If you want to have the default rats lines you need to remove the VOLTAGE and RATSNEST_SCHEDULE = POWER_AND_GROUND properties
    o Edit >Properties (or hover over the net and use rmb 'property edit' when in an application mode)
    o Select the net
    o In the Edit Property GUI select/enable the delete checkbox for the Voltage and RATSNEST_SCHEDULE = POWER_AND_GROUND properties
    o OK the form
  • Ejlersen
    Ejlersen over 15 years ago
    Hi
    Another solution is to delete the no_rat property
    br
    Ole
  • fxffxf
    fxffxf over 15 years ago
    For large pin count nets like those you find on power and ground nets, removing the power_and_grouding ratsnesting method or deleting the NO_RAT property can have a detremental effect on overall product performance.
  • uamcap27
    uamcap27 over 15 years ago
    I don't know what your exactly mean. There is no relation whatsoever between a board performance and power/ground ratsnest. It is just like turning on and off the lights.
    To turn on and off the ratsnest you can go the constraints manager > Properties > Net > General properties. No Rat column click the cell drop down on the net you want to on or off the ratsnest.
