  3. PSpice Capture Lite Error No Pspice Template
  • Replies 26
  • Subscribers 167
  • Views 53884
surferben182
surferben182 over 15 years ago
I am working on a school project involving a power switch and I am using PNP and NPN transistors in my pspice model. When I go to simulate the project, I am getting green circles above the two BJTs and the following error message in the System Log:
WARNING [NET0093]   No PSpiceTemplate for Q1, ignoring
WARNING [NET0093]   No PSpiceTemplate for Q2, ignoring
Both devices are taken from the pspice library, which was what most other forum posts suggested. I tried creating a new project file and building the schematic from scratch to see if that would fix the issue, but it didn't.
Any help on how to get this working would be great.
Thank you,
Ben
  • Abha
    Abha over 15 years ago
    This could happen if your pspice.ini is not configured correctly. You should check the registry value for HKEY_LOCAL_MACHINE\SOFTWARE\Cadence Design Systems\Interchange\ProductConfiguration\Shared\PSpiceConfigFile
    Its value should be path to a valid PSpice.ini file. This file usually lies at \tools\PSpice\PSpice.ini Please check this and let me know if this does not fix the problem. Also please mention which PSpice version you are using.
    .. Abha
  • martychi
    martychi over 14 years ago
    .. Abha
    ok, same problem here...but my registry has no entry whatsoever for HKEY_LOCAL_MACHINE\SOFTWARE\Cadence Design Systems\Interchange\ProductConfiguration\Shared\PSpiceConfigFile...
    should I create that entry?
    if so, tell me EXACTLY what to type...my system is WINDOWS VISTA 64 with ample memory...
    thanks,
    martychi
    ok, I found some advancement, but now stuck on this:
    after running a sim (using PSICE parts in schematic, this comes up...
    WARNING(ORPSIM-15188): There are no devices in this circuit...
    but I do have devices in circuit...all from the pspice library...what is wrong?
  • Abha
    Abha over 14 years ago
    Hi Martychi,
    You should not need the registry entry if you are using a recent PSpice version like SPB 16.3 or SPB 16.5
    In previous versions, the installer used to create this entry.
    If you want to create the entry manually, create the following keys:
    Under HKEY_LOCAL_MACHINE\SOFTWARE\Cadence Design Systems - Create key "Interchange"
    Under Interchange - Create "<release name>" e.g. create key 16.3.0 for 16.3, 16.5.0 for 16.5, 15.7.0 for 15.7 etc.
    Under <release>, create "ProductConfiguration"
    Under ProductConfiguration, create "Shared"
    Under Shared, create String Value with Name = "PSpiceConfigFile" and Value = "<path to ini file>"
    e.g. path may be D:\cadence\SPB_16.5\tools\pspice\pspice.ini
    Please let me know if it helps.
    Abha
  • martychi
     ok, I found some advancement (I no longer need help with the registry issue), but now stuck on this:
    marty
  • martychi
     I have a similar problem...I believe so...
    marty
