  3. keyboard hotkeys
  • Subscribers 163
  • Views 18971
keyboard hotkeys
HWDesigner
HWDesigner over 15 years ago
How can I assign "Control+G" hotkey, such as "grid toggle"?
I've assigned hotkeys from editing the env file inside pcbenv directory with lines of:
funckey "F2" "zoom fit"
funckey "sr" "rats component"
 I've tried funckey "Ctrl+g" "grid toggle" but it doesn't work. Whats the syntac to use the control key?
 Thanks.
  • fxffxf
    fxffxf over 15 years ago
    TRY:  funckey ~G grid toggle
  • HWDesigner
    Thanks, that worked perfect.
    So the tilda means "Control"? It works for uppercase and lowercase "G", which is nice. If I wanted to assign hotkeys using "Shift" key, what is that syntax?
    In my code I use quotation marks around the command name and the hotkey. Is it not needed?
    Thanks.
  • fxffxf
     The 'S' character indicates Shiftand the 'A' indicates Alt. You need to be careful with Alt since Microsoft reserves multiple key combos for its own use.
       alias ~SG grid toggle    - for Control-Shift G
       alias ~AG grid toggle    - For Control-Alt G
       alias ~ASG grid toggle  - for control-alt-shift G
    For control and function keys, the alias and funckey work the same. If you don't use keyboard modifiers then alias and function work slightly differently:
      alias g grid toggle    - Requires you to type g<RETURN>
      funkey g grid toggle - This just requires 'g' with no <RETURN>
    You can play on the Allegro status/command area to see what is done. For example type:
         alias <Control>g
    and you should see
        alias ~G
     The master env file (towards the middle) contains more examples and info
        <CDSROOT>/share/pcb/text/env
  • HWDesigner
    Thank you for your help. Now I understand the difference between funkey and alias.
    Alias is case sensitive. I set up alias for specific grid settings that run a macro, but I created 2 aliases for upper case and lower case.
    For example:
    alias g50 replay grid50
    alias G50 replay grid50
