  3. Design Entry HDL 16.3 - replace 100 components in schem...
  • Subscribers 163
  • Views 3561
Design Entry HDL 16.3 - replace 100 components in schematic
K2J4
K2J4 over 14 years ago
In an existing design I need to replace 100 components in a schematic -- 100 of one type of component being replaced by 100 of another type of component.  Is there a way to quickly replace these components where the rotation of the schematic symbol that is being replaced is retained and the reference designator is retained?
In short, I'd like to replace 100 components but retain the symbol rotation and retain each reference designator.
This is a most dreadful task when doing it manually.  Is this the perfect motivation to learn skill code?  Can it be done in skill code?  Thanks, in advance, for any help.
  • Jerry GenPart
    Jerry GenPart over 14 years ago
    You can consider using the Global Component Replace capability in Design Entry HDL (DEHDL, formerly – ConceptHDL).
    It’s a very efficient GUI driven utility where you can select a component and replace it with another (among other global commands).
    In addition, to preserve the LOCATION/$LOCATION values during the replace, use these project .cpm directives:
        RETAIN_LOCATION_ON_REPLACE 'ON'
        RETAIN_HARD_LOCATION_ON_REPLACE 'ON'
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11233430
    Jerry
  • djhutchi
    djhutchi over 14 years ago
    If this is just another part table version of the same symbol, try using Part Manager to replace the key properties with the new version…
