  3. How to make Closed polygon
  • Views 22528
Raam
Raam over 15 years ago
I imported the dxf to new board file and i changed the dxf line to Board outline, while trying to create the routkeep out with Z-copy, i got the following error
"Not a closed polygon or CLine. Element ignored!"
How to make Closed polygon, please let me know
Thanks and regards
raam
  • oldmouldy
    oldmouldy over 15 years ago
    Get the Shape layer visible then use Shape>Compose Shape, you probably want to remove the existing objects from Board Geometry> Outline and the use the Compose Shape from the imported Class / Subclass and use the Board Geometry>Outline as the target class / subclass for the Compose.
  • KeithP
    KeithP over 15 years ago
     Try "Shape -> Compose Shape"
    KP
  • Khurana
    Khurana over 15 years ago
    Try the Shape > Compose Shape command to see if that helps
  • steve
    steve over 15 years ago
    Use Shape - Compose Shape, check the options fold out menu for class, subclass etc, then window select the imported dxf data. You will get a composed shape on the class/subclass you specified. You may need to delete the imported dxf data afterwards. It can be a good idea to import the dxf data onto an unused class/subclass first.
  • Raam
    Working Good, Thank you Oldmouldy :)
