  3. Allegro reuse module
  • Views 14080
raj090988
raj090988 over 14 years ago
I am new in pcb designing and i would like to know about reuse module ?it is use full or not or it helps us to minimize our work?
  • oldmouldy
    oldmouldy over 14 years ago
    If you have repeated blocks, design reuse can save effort. In current releases, Placement Edit Application Mode has replaced the previous reuse methods - since it is generally more flexible than previous versions using reuse modules and reuse annotation. See the algroplace.pdf, chapter 13 for the 16.5 release, in the doc\algroplace directory of the installation, for the Using Placement Edit Application Mode documentation.
