  3. PCB editor 16.3: How to swap the layers?
  • Subscribers 163
  • Views 14966
Raam
Raam over 14 years ago
I have 8 layer PCB, in that I want to swap middle power layers L4-signal and L5-power plane.
Now I am using sub-drawing option to swap, but while loading the sub-drawing, some vias are missing and it is difficult for me.
If any special option is there ? please let me know. Thank you in Advance,Raam.
  • girish
    girish over 14 years ago
     Simple procedure I follow is
    * Create one  dummy layer.
     * Do edit change (shape & cline) Power plane content to dummy layer
    *  Do edit change (shape & cline) signal layer  content to power plane
    * Do edit change (shape & cline) dummy layer  content to  signal layer
    *Change the layer namings & delete the dummy layer
    HTH
    Girish
  • Raam
    HI Girish, it's worked fine as you say, Thank you :)
