  3. extracta and .pad files
  • Subscribers 163
  • Views 18283
DominiqueP
DominiqueP over 13 years ago
Is it possible to use extracta to extract some data directly from .pad files, such as shapes or thermal relief names ?
I am using Allegro 16.5
  • oldmouldy
    oldmouldy over 13 years ago
    I don't think that there is an extracta method, you could use "pad_designer.exe -nographic -s <script_file>.scr" where script_file.scr contains:
    setwindow form.padedit
    pse_open
    fillin "<pad_file>.pad"
    pse_summary
    setwindow text
    save
    fillin "<report_file>.txt"
    close
    -You would need to build the scripts to dump a list of pad files from a given directory and then look at the pad files generated - you can also get the report from the pad_designer UI on a pad by pad basis.
  • fxffxf
    fxffxf over 13 years ago
     try:   extracta <padstack file> pad_rep  result_file.txt
  • Robert Finley
    Robert Finley over 13 years ago
    Thanks.  I needed that information too.
  • DominiqueP
    Thanks for your answers.
    Finally, I found a solution: I used the following command:
    report -v pad <padfile.pad> <outputfile.txt>
    This command outputs a file in csv format that contains all informations I needed, and even more...
