  3. Orcad 16.6 capture ERROR(ORCAP-5004): Error initializing...
  • Views 5346
Orcad 16.6 capture ERROR(ORCAP-5004): Error initializing COM property pages: Invalid pointer
ChrisZhao
ChrisZhao over 12 years ago
Hi, all
My OS is windows 7, 32bits. SPB version is 16.6.
When I trying to create Netlist, this error happed.
I have searched in this forum, try to debug with the method in this link:
http://www.cadence.com/forums/p/15490/1310574.aspx#1310574
But it didn't work, I went to the (Install_dir)\tools\capture, there was no pxllite.ocx and truereuse.ocx but orpxllite.ocx and ortruereuse.ocx. I run them the same way as previous link, I did got "DllRegisterServer in orpxllite.ocx succeeded." and "DllRegisterServer in ortrueReuse.ocx succeeded." I still can't create netlist. I also trie to run capture "as a administrator", it can't work.
Thanks.
Chris
  • hmkr
    hmkr over 12 years ago
    To diagnose the problem-
    - Please download and rename the attached file pxlreg166.txt to pxlreg166.tcl
    - After the COM error appears, click OK, close the Netlist dialog and provide the following TCL command in the Capture TCL command window-
           source "<path>/pxlreg166.tcl"
           For example, if you downloaded and placed pxlreg166.tcl in  d:/temp folder, then provide the TCL command "source d:/temp/pxlreg166.tcl"
     This command will dump the information regarding the registration of the ocx files and their paths registered in the system registry. This might help in diagnosing the issue quickly.
    • pxlreg166.txt
  • BillZ
    BillZ over 12 years ago
    Hi
    With Win7 make sure you run the Capture.exe as admin.
    You can right click on the capture.exe and choose Run As admin.
    BillZ
    EMA Design Automation
  • ChrisZhao
    I found it was useful to run "Run" as admin, sometimes running "capture.exe" will cause other problem, such as it will keep reminding me "communicating with server", and I have to close capture.
     I found every time I want to create Netlist, I need to register this two *.ocx files. Weird.
  • soccermike
    soccermike over 9 years ago
    Running as Admin fixed the problem.
