  3. A problem with DC-blocked filter
  • Views 12622
slmperl
slmperl over 11 years ago
Hello.
I performed a simulation of filters, When I simulated a lo-pass filter, the results was correct. But, when I tried to simulate a band-pass filter, with a blocking capacitor in front- the results seem incorrect(I compare to LTspice simulator).
I addition (maybe not directly regards that problem), when I checking the current in the ground pin of the opamp- its value is several amps, when the real value is about 1 mA( the other currents, including the power supply currents) seem correct.
I can't attached the file due to our "firewall" security, but I can send it by mail.
Any suggestiopn?
