  3. NC Parameters
  • Views 19826
NC Parameters
Yoda5939
Yoda5939 over 11 years ago
I have what I consider an odd problem. When running standard RS274X art work,specifically NC Drill,, the tool came back and said " ERROR(SPMHMF-362): The number of integer places specified for the drill output data is not enough for this design.
 ERROR(SPMHMF-336): Program terminated."
I had not seen this error before.  THe tool came back later to tell me that I needed to run NC ROUTE.
Whats happening here?
-Ron Scott
  • chads108
    chads108 over 11 years ago
    Our company builds board in millimetetrs, so I run in to this fairly often.  I think, if I remember correctly, the default NC Parameters for Excellon Format is 2.5.  In my case once a board get over 99.99999 millimeters in a direction, that format no longer works and I have to change to 3.5.  I suspect this is your issue.
     As for the NC Route, if you have slots defined in your board, NC Route will define those in a NC Route file similar to the drill file.
     Chad
  • chads108
     Chad
