  3. How to match length of a differential Pair
  • Views 21148
Hossein1357
Hossein1357 over 11 years ago
I want to match the total length of my Diff pairs - all should be in a specified range in comparison to each other. I have defined an Electrical rule set and assigned some min/max margins. Then I assigned that ECS to my three differential nets and analyzed them. I found out that some of them are out of margin. Unfortunately, tune delay can only increase length of every single line not both!. I have some sample boards from various vendors which I see they were able to match diff pairs. I spent lots of time on it. I appreciate any help.
Thanks in advance,
Hossein
  • steve
    steve over 11 years ago
     Take a look at http://www.parallel-systems.co.uk/images/PDF/diffpairs_definition.pdf but when using Delay Tune or Phase Tune if you want both members of the pair to tune together use Right click - and uncheck Single Trace mode.
  • Hossein1357
    Thank you Steve for your help. I will study document. However, I am pretty sure that I had disabled Single Trace mode and it still couldn't tune both pairs!. It is maybe related to improper settings of Differential Pairs.
  • Hossein1357
     Hi Steve,
    I read the document and it helped me a lot thank you very much. I am goign to keep a minimum distance between these pairs. I couldn't reach my design goals by defining Net Class-Class spacing. It seems to me that it is not operating properly. Would you please guide me on this issue as well?
    Hossein
  • BK2018
    BK2018 over 6 years ago in reply to steve
    This still works!
    Thanks Steve!
