  3. Orcad capture symbol copy
  • Subscribers 167
  • Views 21116
ronnoz
ronnoz over 10 years ago
I have to symbol editors open in schematic capture and I want to copy one symbol into the other. When a do a copy and past the pins cumber do not copy. Is there a way I can preserve the pin numbers on a symbol copy and past?
  • alexpioner
    alexpioner over 8 years ago in reply to ronnoz
    ronnoz said:
    I have a part built by someone else in which if I try to split the part Orcad capture gives me the error “ERROR(ORCAP-1260) package cannot be split as it contains 3 parts”
    I had the same problem with the same error. Open the part, and add the User Property with name SPLIT_INST and value TRUE. It had helped in my case.
    Best Regards
