  3. Make round/arc corners on existing shape
  • Views 11309
Vapenhandlare
Vapenhandlare over 11 years ago
I have my PCB design with some complex plane shapes, and I need to turn some 90 degree corners into arcs with a specific radius. When I try to do Manufacture->Drafting->Fillet, I am asked to "Pick first segment to be filled". Here comes my problem. Wherever I click on my shape, I get the following message: "No element found... pick again. Pick the first segment to be filled". I've tried almost everything I could think of: making the shape static, dynamic, changing layer, changing active class and subclass, drawing a new simple rectangular shape and trying my luck with it. The shape is not fixed, i can select it and move vertex, change properties, but making an arc instead of 90-corner is something I need help with. Did anyone experience the same problem? How to solve it?
Thank you in advance for your help!
P.S. Allegro PCB Designer v16.6 (Allegro PCB Designer (was Performance L))
  • oldmouldy
    oldmouldy over 11 years ago
    Fillet works on lines, not shapes, hence the "No element found". You need to: either, convert the shape boundary to lines by Decomposing the shape, adding the fillets and then Composing the shape; or, use the Shape Edit Application mode, you need at least hotfix 51 / 52 installed to get the Shape Edit Application mode.
  • Soundman99
    Soundman99 over 11 years ago
    oldmouldy is right. If you do not have the latest hotfix, then you can also follow these steps, although controlling the radius will be more difficult. 1) General Edit mode 2) Shape -> Edit Boundary 3) Pick the shape 4) change the Segment Type from line to arc (found in the options menu). Select near a corner on one edge and draw the arc to the other edge.
